Old 9/24/09, 5:54 PM
David K. Kraemer David K. Kraemer is offline
Default No Drip Loop
I understand that the conductors all have a reasonable amount of fall, but there is no "loop". So is this right or wrong?
David K. Kraemer
Inspector Catch-it
http://www.inspectorcatchit.com
(661) 948-3375
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 9/24/09, 6:29 PM
Jeffrey R. Pope's Avatar
Default Re: No Drip Loop
Uphill rise to the mast-head. It's not "pretty," but it's fine.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/24/09, 6:41 PM
That's what I was figuring, but just wanted a second opinion. Thanks Jeff!
David K. Kraemer
Inspector Catch-it
(661) 948-3375
Old 9/24/09, 8:35 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I would agree with Jeff. And it looks like you had an audience for the exterior portion.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 9/24/09, 9:19 PM
wsiegel wsiegel is offline
Those shingles look a little rough, and those look like exposed nails on the shield
Old 9/25/09, 6:14 PM
Eric Krause Eric Krause is offline
Am I missing something here? Those look like the service entrance conductors. I cannot be sure of the dimensions and clearances from the picture but it looks as though the issue of the drip loop should be secondary to the apparent lack of proper clearances from the roof. If the masthead is less than 4 feet horziontally from the roof edge there must a minimum of 18" clearance to the roof. If masthead is over 4 feet to edge the clearance must be 3 feet if roof slope is equal to or greater to than 4 in 12, and 8 feet of clearance is required for slopes less than 4 in 12. This is a quick paraphrasing of the IRC and NEC but the conductor clearances sure look suspicious from looking at the picture and should be addressed before/in addition to the drip loop.
Drip Loop Neutral Disconnected pabrioux Electrical Inspections 3 10/13/08 2:31 PM
Marginal Drip Loop. Erol Kartal Electrical Inspections 9 8/3/08 6:37 PM
Drip Loop chunt1 Electrical Inspections 5 1/31/07 6:52 AM
Drip loop? jspringstead Electrical Inspections 1 7/5/06 9:25 PM
