Today I found this no main disconnect on main panel box. What do you guys have to say about this.
A split bus. Six or less throws completely disconnects the service. No problem there.
Double tap upper left.
I don't like the double pole breaker feeding off down to (what appears to be the same buss bar? No main disconnect. What is the multi strand aluminum looking wire right side of box? |
Also, and I am guessing and going solely on the photo, but..
The middle left bridged breaker (60 amp) appears to have undersized wire for 60 amp breaker? |
Agree with Jeff, six throw rule okay.
Agree with Ray, double tap upper left. Middle breaker right hand side (40 or 50 amp) double pole tie to neutral appears a tad burnt... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Jeff,
I have always respected your posts and advice..but how do you come up with Six or Less here? Harvey Gordon - President - FloridaNACHI (The OFFICIAL Florida State Chapter of NACHI) SEFloridaNACHI (Serving NACHI Members in Martin, Palm Beach, Broward, Miami-Dade, and Monroe Counties) ______________ Questions or Comments about FloridaNACHI or if you would like to start a LOCAL Florida Chapter may be sent directly to me at hgordon@fl.nachi.org ______________ |
Earl
I assume they are the ground wires? I see copper going under terminal screws of breaker, were does the aluminum fit into the picture. Work with me, I am going by a photo, my eyes are dim I cannot see.... |
It's possible that the double tapped breaker is not tied together, but I can't tell for sure. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Like I said...you da man!
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jeff is correct!
hard to make out the left side of the panel from the photo. Configuration is for 6 throws which is acceptable. Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
. ............ my call would be! Main panel (Immediate Further evaluation by qualified person.) I think there is too many concerns to start and list them all. It is wrong and must be fixed . Roy Cooke . Royshomeinspection.com..... |
Stranded AL is not a problem.
| Main disconnect at meter instead of main panel. OK? | kshepard | Electrical Inspections | 14 | 11/8/06 7:24 PM |
| Tenant access to main disconnect in apartment bldg? | lhoffman | Electrical Inspections | 4 | 9/1/06 12:54 PM |
| No main disconnect? | mboyett | Electrical Inspections | 25 | 8/7/06 12:53 AM |
| Disconnect and Main panel | srowe | Electrical Inspections | 10 | 6/13/06 8:49 PM |
| Main Disconnect Manufactured Home | dbreen | Electrical Inspections | 1 | 3/4/06 1:42 PM |
