Does the NEC allow non-grounded GFCI? As long as it is labeled "non grounded"?
774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I believe so. Also Nachi says it's ok.
http://www.nachi.org/ungrounded-elec...eceptacles.htm |
Non-grounded GFI's are fine. One side note; the three light tester will not trip them.
Interesting. Didn't know that about the three light tester. I was calling these out as defective. I guess I will need to test them with the receptacle's Test button also from now on. Does the Sure Test tester trip them?
I don't believe there is a requirement or need need to label "non-grounded".
Nongrounding-Type Receptacles 406.3(D)(3) Nongrounding-Type Receptacles. Where grounding means does not exist in the receptacle enclosure, the installation shall comply with (a), (b), or (c). (a)A nongrounding-type receptacle(s) shall be permitted to be replaced with another nongrounding-type receptacle(s). (b)A nongrounding-type receptacle(s) shall be permitted to be replaced with a ground-fault circuit interrupter-type of receptacle(s). These receptacles shall be marked “No Equipment Ground.” An equipment grounding conductor shall not be connected from the ground-fault circuit-interrupter-type receptacle to any outlet supplied from the ground-fault circuit-interrupter receptacle. (c)A nongrounding-type receptacle(s) shall be permitted to be replaced with a grounding-type receptacle(s) where supplied through a ground-fault circuit interrupter. Grounding-type receptacles supplied through the ground-fault circuit interrupter shall be marked “GFCI Protected” and “No Equipment Ground.” An equipment grounding conductor shall not be connected between the grounding-type receptacles. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I stand corrected.
Yes, if you have the ground-continuity adapter.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 8:33 PM |
