cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone know if a smoke alarm/dectector that is 20 feet above the floor "has" to have battery backup? My 80 year old, home alone, lady client doesn't like changing the battery this high up.
Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Must it have a battery? Only if the IRC applies to that dwelling. It seems that your choices are battery only, or commercial voltage with battery backup.
R313.2 In new construction, the required smoke alarms shall recieve their primary power from the building wiring when such wiring is served from a commercial source, and when primary power is interrupted, shall recieve power from a battery. Wiring shall be permanent and without a disconnecting switch other than those required for overcurrent protection. Smoke alarms shall be permitted to be battery operated when installed in buildings without commercial power or in buildings that undergo alterations, repairs, or additions regulated by Section R313.1.1 Smoke alarms are available with a remote battery source, such as those as the ADT type low voltage fire alarm systems that run to a central panel with a large battery backup for the whole system. |
It just dawned on me that many local fire departments will come out and change the smoke detector batteries for older folks as a community service. They even provide the batteries. Maybe this person should just keep the non-emergency number for the fire house handy, and they can come out every once in a while and square her away?
I'm a little worried about the proposal to mount the detector lower, as the detectors are to be mounted within (12" ?) of the ceiling to function as they are intended. |
The lithium batteries in low-drain detectors are good for 10 years - at which point you ought to change out the detector anyway.
http://www.amazon.com/Ultra-Battery-.../dp/B00004W3ZE What makes ME crazy (I live in a house with cathedral ceilings) is trying to figure out which detector is producing a low-battery warning "beep" - "there outta' be a law" requiring an LED to come and stay on when a low batter conditions is detected. Last edited by mthomas2; 3/6/07 at 11:56 AM.. |
http://www.usfa.dhs.gov/downloads/pyfff/smkalarm.html If an alarm is mounted on an exterior wall or a ceiling below an unheated attic that is poorly insulated (the surface gets noticeably cold in the winter and warm in the summer), the temperature difference can prevent smoke from getting to the alarm. Placing the alarm on an inside wall avoids the problem. In desert climates where evaporative coolers are being used, mount smoke alarms on walls 12 inches below the ceiling. These coolers add moisture that can cause the smoke to drop. Older adults may have difficulty reaching alarms on the ceiling to change batteries. If hard-wired alarms are impractical, wall mounting 12 inches down should be considered. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
The 12" requirement is modified for sloped or peaked ceilings:
http://www.brkelectronics.com/downlo...to_install.pdf |
Hum... now this is cool: a smoke alarm you can silence (including low-battery alert) using most TV remotes:
http://www.firstalert.com/manuals/M08_0071_002E%20(SA302_HD)WEB.pdf |
If there is any "code" on smoke detector mounting, it is in NFPA 72, The National Fire Alarm Code.
There's lots of information in ther about mounting heights and spacings of heat detectors, but oddly, very darned little about smoke detectors. The guidance basically given in NFPA 72 with regard to smoke detector placement is: -Don't install them in areas below 32°F, over 100°F, over 93% humidity, and in places with more than 300 ft/min air velocity. -In large rooms, space them no more than 30 feet apart. -Follow manufacturer's instructions. |
My "Free Smoke Detector Installation" program offers battery operated smoke detectors that have 10 year batteries. So no battery changing, just smoke detector changing in 10 years.
tom |
I have argued with IAEI guys about this for years. They will say NFPA72 requires the detector up in the tray or on the ceiling of a vaulted ceiling near the peak, in spite of the fact that this is never going to be accessible to the homeowner.
It can cost up to $100 to get these batteries replaced and as often as not they will just have the guy take the detector down and put a blank cover over the hole. Now, in the effort to squeeze the last .01% of effectiveness out of the detector they have created a situation where they will likely end up with zero. If I was an HI I would point out detectors that are not accessible as an issue they have to consider. That battery will die (if it has one in the first place) and it will be a pain to replace. Bear in mind, more people are killed and injured every year from falls than fires. |
BTW I would call a smoke detector in a tray with a fan as a defect
Do you have a photo example of this specific configuration? If you can't post here please email: adairinspex@adairinspection.com ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Hi to all,
while we're on this subject, this weekend the clocks move forward, many authorities suggest checking alarms and replacing batteries at this time. It's also a good excuse to email your former clients with a timely reminder. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
| 2 questions | staylor5 | Electrical Inspections | 14 | 12/18/09 2:32 AM |
| Escape, Fire & Smoke Alarms | badair | Interior Inspections | 14 | 1/28/08 7:21 AM |
| QOD for 1/22/07 (Smoke Detectors) | jbowman | Inspection Question of the Day | 9 | 4/14/07 8:33 AM |
| smoke detectors in bedrooms | bgraham | Electrical Inspections | 3 | 1/27/07 1:19 PM |
