Old 1/19/12, 5:12 PM
Jeffrey R. Pope's Avatar
Default Not Quite Grounded
On today's morning appointment...
This is in the raised foundation. The grounding electrode conductor (GEC) is attached to the flexible metallic conduit, which is obviously wrong, but the kicker - the FMC never even touched the ground. It came out of the service panel and traveled about three feet, directly into the kitchen.
The sellers agent said, "this house was built to older codes, and this was allowed back then." My client is a retired electrician (IBEW), so I just smiled
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/19/12, 5:30 PM
Roy D. Cooke, Sr's Avatar
Default Re: Not Quite Grounded
The outer jacket of BX was not for grounding it was for wire protection .
There was a single wire inside or a flat aluminum strip for grounding.
They have found current in the Jacket caused a lot of fires .
This looks Like a steel jacket real old ... Roy
Old 1/19/12, 5:56 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Well that will be an easy fix for your client. Good thing there were no lightning strikes.
Old 1/19/12, 7:14 PM
That was my thought as well.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Clarification on Detached Building krigler Electrical Inspections 13 9/20/11 9:29 AM
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
