I have not seen this before but it seems rather wrong, the screw and the washer were not hot, but why would one do this on the main breaker.
![]() ![]() There were other electircal issues going on at this place so a call out to an electician, should this also be flagged, just seems so wronb to have something like that between the breakers Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
This appears to be a breaker designed to be held in place since it is a 100A breaker, It must be connect securly to the panel enclosure. This is done to keep the breaker from popping out due the increased size of the wire plus the NEC calls for it to be screwed in is back feeding a breaker used as a main.
Sorry I am being brief and lax on the explanation...I will do better when I am back at the office as I am tapping this in from a job on my pocket pc. Paul W. Abernathy |
Thanks Paul that is all I needed
Regards Joe Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
I suspect that is a back fed breaker and they are required to be secured to the enclosure.
That's how the backfed main hold down's are on Cutler-Hammer BR panels.
Was this a BR panel? |
