Old 4/21/09, 9:47 AM
Spencer B. Johns's Avatar
Spencer B. Johns Spencer B. Johns is offline
Default This is not a test
aaaa
Spencer Johns
360homeinspections.com
TREC#8580
Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America)
Old 4/21/09, 10:44 AM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: This is not a test
The white wire on the bottom left breaker should have been re-identified as a hot conductor.
The double tap in the 3rd photo should not be an issue as long as the wires are properly sized. Square D, both QO and Homeline are listed for use with 2 conductors in 15, 20 and 30 amp.
Old 4/21/09, 10:45 AM
Unmoderated Guest
This is service equipment. The neutrals and grounds on the same buss is fine. However, the neutrals all need to be one per hole, no sharing.
Old 4/21/09, 10:48 AM
Unmoderated Guest
Hard to tell from the angle, but what is going on with the 2 double pole breakers on the right side bottom?
Old 4/21/09, 11:01 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
Originally Posted by sjohns View Post
aaaa
here we go again
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 4/22/09, 6:39 AM
Sorry...I dont see an image so i can't comment.
Paul W. Abernathy
Please post questions about anything having to do with roofing kshepard Exterior Inspections 165 6/17/09 11:47 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Inspection of HVAC by an area inspector. dmcauley Inspecting HVAC Systems 13 3/21/07 11:03 AM
Home Inspector Test Or Das Fazaland Home security test??? mlaverty Legislation, Licensing & Legal Issues for Inspectors 0 9/20/06 10:42 PM
