Old 9/24/11, 9:37 AM
Gilles Larin Gilles Larin is offline
Default Obligation to open a service panel during a Home Inspection
Hi Fellow Inspectors,
I'm trying to find out what is the average Home Inspector's practice when inspecting a residence during a pre-purchase inspection with respect to opening i.e. "taking off" the front panel to see how the connections are made etc.
My question to you is:
  • Do you do it as part of your inspection?
  • Are you obligated to do it where you inspect?
  • Which Standard of Practice / law governs this where you inspect
I inspect in more than one jurisdiction and the practice varies even within one jurisdiction and your answers would be informative and most welcome.
Thanks
G.
Gilles R. Larin,
www.inspectapro.net
National Home Inspector Certification #378;
Certified Inspector: ANIEB; ASHI; InterNACHI; PHPIC
IAC2 Certified #IAC2-00-9310
Certified Thermographer Level II
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/24/11, 10:08 AM
Jeffrey R. Jonas's Avatar
Default Re: Obligation to open a service panel during a Home Inspection
Gilles,
I inspect in Minnesota state (occasionally Iowa)...
1) Yes, always, unless there is a condition present that potentially effects my personal safety.
2) No, there are no licensing requirements at this time.
3) As an inspector in Minnesota (Iowa) with no licensing laws, my personal SOP is all that is needed, but as a member of InterNachi, the InterNachi SOP is what I comply with.
Jeff
Old 9/24/11, 10:11 AM
Jeffrey R. Pope's Avatar
  • Do you do it as part of your inspection? Whenever possible.
  • Are you obligated to do it where you inspect? "Expected" (not obligated) when the panel is safely accessible.
  • Which Standard of Practice / law governs this where you inspect? We have no state law/requirement with regard to Home Inspections in CA, so nationally recognized standards are the normal guide.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/24/11, 10:19 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
I would question a report that didn't involve inspecting the inside of a panel. Unless if were unsafe of course.
Old 9/24/11, 3:03 PM
Marcel Gratton's Avatar
I agree with Robert M!
On The Level Inspection
Gatineau, Québec
Old 9/24/11, 9:27 PM
Joseph Hagarty,  CMI's Avatar
My Inspectors would use the same screwdriver (For WDI Probing)
that they used to remove Electrical Panel Covers.
If a 24 inch Screwdriver did not fit
to remove panel cover screws.......
Panel did not have proper access (30 inch required)...
End of Panel Inspection.......
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 9/25/11, 8:21 AM
Robert J. OConnor's Avatar
I'm not aware of any national or state standards of practice that do not require an inspector to remove a panel cover to inspect the interior components, unless there is a valid reason not to like an unsafe condition.
Even in states without licensing, where an inspector also does not belong to an inspection association which require members to follow the association's standards, the inspection agreement better reference a nationally recognized SOP for liability reasons.
JMO & 2-Nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
www.reporthost.com/-rjo
Old 9/25/11, 8:47 AM
LeRoy D. Holm's Avatar
LeRoy D. Holm LeRoy D. Holm is offline
The only time I never removed the panel it was caulked shut and removing would damage the wall. Asked owner of home to remove and they refused. If the cover is not removed what is hiding in there. I always remove unless I run into another situation like this
www.tristatehomeinspections.org
www.tristateenergyinspections.com
If you always do what you always did you will always get what you always got.
Old 9/25/11, 5:11 PM
Kenneth R. Brittain Kenneth R. Brittain is offline
North Carolina is a Licensed state and the SOP requires removal of the cover unless its not readily accessable or its unsafe. There is no difference between an inspection for the seller or buyer.
Old 10/6/11, 7:17 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
In Wisconsin:http://legis.wisconsin.gov/rsb/code/rl/rl134.pdf
(7) ELECTRICAL SYSTEMS. (a) A home inspector shall
observe and describe the condition of all of the following:
1. Service entrance conductors.
2. Service equipment, grounding equipment, main over current
device.
3. Main and distribution panels, including their location.
4. Amperage and voltage ratings of the service, including
whether service type is overhead or underground.
5. Branch circuit conductors, their over current devices, and
the compatibility of their ampacities and voltages, including any
aluminum branch circuit wiring.
I don't know how many of these items can be reported on, especially number 5, without removing the dead front.
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Old 10/6/11, 8:50 PM
James H. Bushart's Avatar
Thanks
G.
Your question raises another issue that should be addressed, IMO.
If you have a comfort issue that causes you to hesitate to remove the dead front --- don't do it until you are comfortable. Killing yourself and/or damaging someone's property is never the proper manner in which to conduct a home inspection.
Until you are comfortable, however, refrain from doing home inspections for this part of an inspection is very important and should not be excluded unless it cannot be done safely. Find someone to tag along with until you feel up to snuff.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 10/6/11, 11:35 PM
I frequently remove panels / BUT not always.
Last week, I had a 5' high panel (600amps / 3 phase) with a 24" wide steel tool bench (about 12' long in front of it). It had water dripping out of the corner of the panel (conduit had pulled loose from meter base outside). I debated for probably 7-8 seconds / Then told buyer and realtor I was not going to access the panel. Both threw a hissy and told me that was MY job.
I politely laid my 6-in-1 screwdriver and electric screwdriver on the tool bench, went and sat down on a bar stool and said "I'll discount my fee $100 and watch either of you 2 do it".
5 minutes later with no takers we proceeded onward. I'll bet there is some young DUMBO inspector that thinks opening that would be his DUTY.
Old 10/6/11, 11:47 PM
Dale Duffy's Avatar
I'm guessing Gilles being in Canada asked the question with regard to the electrical codes not allowing anyone but a Licensed Electrician legally able (by law) to remove a Panel Cover...
I believe I've seen this discussed several times regarding Canadian Electric Codes and/or Violations.
Old 10/9/11, 12:10 AM
Oh my wouldn't that shorten my inspections?
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
Bungalows to Mansions Professional Home Inspection, LLC bgraham Miscellaneous Discussion for Inspectors 7 1/11/09 3:03 PM
