Old 9/10/07, 4:31 PM
Barry Adair's Avatar
Default Odd find
or maybe not.
This switch is located in an upstairs bedroom it controls
2 receptacles in that room, 2 walls
3 in the next bedroom, 3 walls
1 in the hallway between these rooms
and 1 exterior double flood light fixture, also mounted under the soffit between the 2 bedrooms
The exterior light is not on a photocell so it is on whenever the receptacle are in use and obviously having "control" will only cause another problem down the road for the parents.
Client asked if this is a CODE ISSUE and I can't find anything.
Watch out for your bumper!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/10/07, 11:07 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
Default Re: Odd find
Originally Posted by badair
or maybe not.
Barry,
Definitely an interesting and strange find!!
I scoured the IRC and the NEC and could find no code references for this situation. Obviously it is not only a useless arrangement but also a safety issue as well. There are no code references to positive control, in the same room, of switch controlled receptacles. However it could be a significant safety hazard.
This is a very good question to post, and suggest a change for, on the ICC WEB site BB ( http://www.iccsafe.org/cgi-bin/ultimatebb.cgi )!!
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 9/10/07, 11:51 PM
This may violate the spirit of 210.52 but there is no language I know of that says the required receptacles in a given wall space can't be switch controlled or that switch needs to be in the room.
Old 9/11/07, 5:36 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Too much involvement during the electrical rough in by a guy who 'knows' electrical....
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 9/11/07, 7:00 PM
Mike,
Too cryptic a reply please e-x-p-l-a-i-n to an old county boy.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/11/07, 7:13 PM
Barry I had to chuckle when I saw your post.
I said is the switch to low or is the receptacle to high.
In reading your breakdown, it triggered an old memory when I was a kid.
The switch was obviously in the Master Bedroom and the originator of that dwelling had it set up that way so when the Boss of the family household, usually the Mother, said lights out kids time for bed.
She meant it.
No more reading in bed after bedtime. ha. ha.
Handi-cap accessible driveway, Barry? I think you need risers on your front suspension. ha. ha.
Marcel
Old 9/11/07, 9:50 PM
rromoser's Avatar
rromoser rromoser is offline
Perhaps the switch in question has been replaced and the wire connections inadvertantly swapped around. I've run into this numerous times in 30yrs. of being a sparky. Lots of switches have a hot in and a hot out romex and a switching romex. The hot is tapped for the switch to typically control the light in its room. If the hot out romex and the switching romex connections get crossed everything downstream of that switch in the circuit is now controlled by that switch.
Old 9/12/07, 12:06 AM
Manny,
I took your advice and posted on ICC
http://www.iccsafe.org/cgi-bin/ultim...=001338#000005
You may have to login for the link to work.
So far no violation noted except what we all already knew either the sparky was an a bulb short or this was done by "Handy Dan/Donna the Homeowner" or one of their friends or relatives, like good ol' Uncle 3Fingers
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/12/07, 12:43 AM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
that type of set up i did see that maybe two or three time so far but that switch is used for kinda like master switch for bedroom lumiaires and repectales when they have to deal with some kids IMO it can get really confuseing with this type of set up if you are not famuiar with it
Merci , Marc
Old 9/12/07, 8:01 AM
David P. Valley's Avatar
Barry,
That switch was installed for the midgets that lived there.
And that driveway isn't that bad, compared to this one...
"Click to Enlarge"
Attachment 14445
Old 9/12/07, 8:58 AM
Dave, I think we were at the same house...June of 2006, I think.
Larry Kage, CMI
231 929 3525
Old 9/12/07, 8:25 PM
Originally Posted by dvalley
Barry,
"Click to Enlarge"
Attachment 14445
OH mon dieu !!! that is pretty steep driveway
It nearly blew my mind away with this photo how the heck they can pass this one ??
I dont know if i can ask you a question there is a photo area where ya can show some major goof in this forum ??
If you have it i can send some photo i did work on trailer park some of the stuff ya just can't belive it.
Merci, Marc
Old 9/12/07, 11:24 PM
Must not snow there
Old 9/13/07, 2:38 AM
Rollie Meyers Rollie Meyers is offline
Please Note: Rollie Meyers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Were those homes by any chance in British Columbia?
Old 9/13/07, 10:40 AM
This is what I add to reports for general information for driveways when installation is questionable.
http://www.iowasudas.org/documents/5I-4-06.pdf
Someone really wants to own a home badly to buy the ones in those in the photos.
I'll be looking in another neighborhood and would have to fire an agent trying to get me into one of those homes.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Preemptive Spark Helps Find Electrical Short Circuits In Airplanes mbledsoe Electrical Inspections 0 6/21/06 3:30 PM
