I was testing outlets in a kitchen when I ran across an odd thing.
When I plugged my 3 light tester into the GFCI outlet it tripped instantly. This also happened in a second GFCI farther down the counter. The test button, on hand held, was not depressed. Both GFCI's functioned normally with the internal test buttons and downstream protected outlets showed normal and did trip the GFCI's on the hand held tester in the normal fashion. I tried this a few times always with the same result. Other GFCI outlets in the home all tested normally with the 3 light and with their internal testers. Do any of you have ideas about what is going on here? I wrote them up as I found them and recommended replacement. Jonathan |
no. It did its job.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
http://www.codecheck.com/gfci_testing.htm
http://www.ul.com/consumers/groundfault.html http://ecmweb.com/mag/electric_think_gfci/ http://ts.nist.gov/Standards/Global/upload/gannon.ppt ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 12/10/07 at 11:30 AM.. |
Barry, Thank You for the information.
Jonathan |
Proper testing of GFCI and AFCI is done with their integrated test buttons Check your testers on a known properly functioning GFCI receptacle before using in the field. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 9:33 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 1:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 10:31 AM |
| UL Information about Testing of GFCIs | jtedesco1 | Electrical Inspections | 0 | 2/5/06 5:38 PM |
