Old 12/20/08, 1:17 PM
Default Oil Filled Electric Space Heater
These things seem to be all the rage here this winter. Even on sale, they're more expensive on a $/kw basis and no more efficient than a conventional electric space heater. Am I missing something?
Old 12/20/08, 1:26 PM
Marc D. Shunk's Avatar
Banned
Default Re: Oil Filled Electric Space Heater
The heat is just more "even". They do absolutely nothing to save energy. Not one single thing about filling the area around the elements with oil will save energy, make more heat, or reduce the number of times the heater has to run. The extremes in temperature between on and off cycles are just evened out since the oil bath will continue to radiate a bit in the off cycle, and it takes time to warm back up during the on cycle. If you surrounded your regular electric space heater with buckets of oil, or surrounded it with another mass like bricks, you'd accomplish the same thing.
Old 12/20/08, 1:33 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Dont knock electric, Everyone says their more expensive, but not necessarily.
Nov of this year, I heated exclusively with electric, (the very oil-filled heater mentioned) and my electric bill went up about 60-80 bucks. Compared to 150-200 a month in propane, I'm not doing that bad.
Old 12/20/08, 1:36 PM
Banned
The main way people save money with electric space heaters, whether oil-filled or not, is that they turn the main house heat pretty far back and only heat the room or rooms they live in. The sale of an old mansion-type house near me went though a couple years ago. I did a good bit of work in that house for the former owners, and they told me their winter fuel oil bill could run 3 to 4 grand a month. When I recently learned from another contractor that the new owners were just a couple (two people) for that big house, I asked him what they did for work to be able to afford to heat that place. He replied they just ran space heaters in a few rooms.
Old 12/20/08, 1:53 PM
Michael Larson's Avatar
Good for you.
It all depends on the cost to produce a BTU for each fuel type.
Here is an energy calculator in a spreadsheet format that you can play with.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 12/20/08, 5:07 PM
jkogel jkogel is offline
I may be wrong and will soon find out, But if you have the capacity in your electrical panel, you could get even better efficiency with 240 volt baseboard heat. Safer as well.
John Kogel
www.allsafehome.ca
Old 12/20/08, 5:10 PM
John Kogel
www.allsafehome.ca
John
The efficiency of all electric heaters (120V or 240V) is the same, 100%.
There's no stack so every single Watt goes to heat the house.
Old 12/20/08, 5:22 PM
You're right about efficiency, John. There's other reasons why 240V baseboards are a better choice, like more even distribution maybe. Thermostat locations. Even load on the service panel, both busses, no load on the lighting circuits.
Old 12/20/08, 6:55 PM
Banned
Yeah, none of that makes any sense when we're talking resi. No difference if you have one big 240 heater on both legs, or two small 120V heaters on different circuits. The "balance" of a resi panel is almost never a concern.
Old 12/20/08, 11:43 PM
Unmoderated Guest
And element type electric baseboard is heat is not exactly "safe". The only safe ones are the hydronic electric units, but they are quite a bit more expensive to buy.
Old 12/21/08, 8:18 PM
I recommend plugging your space heater in here...receptacle by Vince S.
Old 12/22/08, 11:56 PM
hey, are those "half hots" on the bottom?
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Electrical Safety Media Center jtedesco1 Electrical Inspections 1 3/15/08 9:18 AM
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 72 3/12/08 12:19 AM
