Old 9/17/11, 12:26 PM
Michael Larson's Avatar
Default Is this OK?
Sometimes you just have to wonder at what you see.
Michael Larson
Hudson, WI
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/17/11, 12:42 PM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
Default Re: Is this OK?
That looks like a satellite cable.
Try this:
Old 9/17/11, 12:52 PM
Try this:
Yep.
Here is the other end.
Michael Larson
Hudson, WI
Old 9/18/11, 7:50 AM
Robert J. OConnor's Avatar
I noticed they used a tee at the bottom of the riser, which should have been an elbow so it doesn't trap moisture.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 9/18/11, 7:52 AM
There is a drain hole in the tee and this is a very common installation.
Michael Larson
Hudson, WI
Old 9/18/11, 8:17 AM
Is that just capped with a hole in the tee? It didnt look like a "drain tee" ... typically only used for Z vent locally.
Robert O'Connor, PE
Old 9/18/11, 8:25 AM
I see these often Robert.
Nothing unusual.
It's not a condensing furnace.
Michael Larson
Hudson, WI
Old 9/18/11, 8:29 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Caulk shrinkage. Needs to be recaulked.
Old 9/18/11, 8:32 AM
Maybe add some foil tap too
Michael Larson
Hudson, WI
Old 9/18/11, 9:12 AM
I would hope it's not, since that is B-Vent ...
Thats what makes me question the use of a tee with provisions for drainage. I would typically only see that for a chimney/flue on condensing equipment. A B-Vent chimney with standard equipment would typically just have an elbow at the base, since there isn't a significant concern about condensate or moisture at the chimney bottom with a proper rain cap.
I would be concerned with field drilling a hole in the side of a manufactured product, no matter how common it was. And moisture would have to sit in the base, and then spill over into the double wall space before it even reached the hole. Not good, as any minor amounts of moisture in conventional venting should drain back to the equipment where it's burned off (from mfr instructions on every standard furnace/boiler I have worked on).
Attached is a pic of a manufactured vertical drain tee typically used for mid-efficiency equipment (Z Vent), with provisions for positive drainage, with no trapped moisture.
Just my take on things ...
Robert O'Connor, PE
Old 9/18/11, 11:42 AM
I have never seen the one you pictured, Robert.
I have seen the one I did many many times.
FWIW, the furnace was a mid efficiency draft assisted unit.
Michael Larson
Hudson, WI
Old 9/19/11, 9:08 AM
Thats a manufactured specialty product, but I probably would be okay with something similar that is field assembled ... say a field drilled hole in a cap at the base of the tee ... not the tee itself. And I would still be concerned with access to the tee cap in order to clean out any debris.
P.S. How often do you see double-lug neutral wires in a panel ...
Robert O'Connor, PE
Old 9/19/11, 10:50 AM
Roy D. Cooke, Sr's Avatar
Too often about 20% I think ... Roy
Many do not know this can burn out equipment more often the Double Taps on the hot wires
Old 9/19/11, 12:01 PM
Double lugged neutrals are a problem.
Neutral paired with safety ground of same circuit. Not so much.
Michael Larson
Hudson, WI
Old 9/19/11, 12:02 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Nevertheless still an NEC violation.
