Hey guys, will you give me a little help on this panel set-up. It's a 100 Amp Square D panel. The potential issues I see are:
Rigler Home Inspections Hays, KS 67601 785-656-0272 Last edited by krigler; 11/29/09 at 6:50 PM.. |
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
The double tap on the main is wrong because its a double tap and the wire for the AC is that is double tapped is undersized now. Also, the neutrals and grounds should not be under the same terminal and the wires entering the panel should be in a protective chase.
I am not an electrical expert, but that's what I see. I am sure others will chime in. It looks like they need an electrcal upgrade. Priority Home Inspections has teamed up with the Dish Network to give you a FREE Dish Network system. Log onto www.Free-Dish-For-You.com for all the details. Priority Home Inspections, Inc. 321-368-9921 www.BrevardHomeInspector.com www.AvoidAMoneyPit.com www.BrevardInsuranceSavings.com www.BrevardBuildersWarranty.com www.PrioritySignPosts.com Info@BrevardHomeInspector.com |
Two-wire systems are indicative of older electrical systems. The electrical wiring systems that power the conveniences of modern life are hidden in walls and in panel boxes in basements. They are out of sight and out of mind. But that does not mean they are not overloaded and under severe stress.
Older electrical systems may show signs of deteriorating wire covering. Some systems may appear to be in good condition, may stress over the years may cause a weakness in the wiring that is not visible or noticeable. Systems over 50 years old should be tested for safety by a licensed electrician. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
The electrician took a short cut. While the wire is under sized for the ac from the double tap, it is protected. The double tap at that location is wrong. The electrician should have put in a sub panel wired correctly and would have been sufficient to move or add additional circuits. I agree with the other posts it should be written up.
The bare service neutral is a definite no-no. I saw a missing clamp fitting in the 3rd photo also. Lots of work for an electrician here.
| Federal Pacific Question. | lrollins | Electrical Inspections | 27 | 11/25/09 12:01 AM |
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
| older homes with Mario Kyriacou, | rcooke | Canadian Inspectors | 45 | 5/9/08 5:30 PM |
