Old 8/4/09, 1:23 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Older panel...need recommendation
First time Ive ran across this type of configuration.
House had a pretty new air conditioner and heater wired
to it.....Should I recommend upgrading to a newer panel ?
David
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 8/4/09, 11:16 AM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Older panel...need recommendation
Why do you think that the service or panel would need to be upgraded? That is possibly a 200 amp fused panel already.
What size wires or cables fed the panel? What sizes were the fuses?
Old 8/4/09, 11:50 PM
wward wward is offline
Please Note: wward is a non-member guest and is in no way affiliated with InterNACHI or its members.
the old HVAC most likely was less energy efficient meaning the old system had bigger wires and bigger breakers. just make sure the existing circuit and breaker are a match for the HVAC system and let it ride
Old 8/6/09, 1:49 AM
rbibler rbibler is offline
Please Note: rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would call it out for replacement do to the age of the thing. When I see old stuff it need service if nothing Else. just pulling the thing apart and looking in on the back side is a good idea. then checking every connection for the correct toque. its just filthy inside.
Best
Ron
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
