Old 7/31/07, 2:37 PM
PAUL J. MAGRONE PAUL J. MAGRONE is offline
Default One panel in the garage
If the main disconnect is located in the garage and that is the only panel present, do the ground wires and neutral wires have to be separate? This panel looks very sloppy to me the way the ground and neutral wires are run to the buss. Some are sharing the same lug. How would you write this in the report?
Old 7/31/07, 2:49 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default Re: One panel in the garage
Grounds can be ganged,
Neutrals cannot; they must terminate under their own individual terminal lug.
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 7/31/07, 2:53 PM
Mike Whitt's Avatar
Unmoderated Guest
If this is the main then the two can land on the same bar.
What is do see wrong is the grounded (neutral) and equipment grounding conductors under the same screw
Does anyone see the main bonding jumper? I don’t see anything that is bonding the panel enclosure to the grounded (neutral) conductor.
Old 7/31/07, 2:56 PM
Michael R. Boyett's Avatar
There's a green bonding screw...top right of the buss.
Old 7/31/07, 3:09 PM
This'll help...
- Mike
NACHI05040682
(843) 442-9755
Old 7/31/07, 8:29 PM
Mike Whitt's Avatar
Unmoderated Guest
Is the screw I have pointed to here the bonding screw?
Old 7/31/07, 8:40 PM
Mike,
It's the one right above the one you've identified...
- Mike
NACHI05040682
(843) 442-9755
Old 7/31/07, 8:41 PM
Michael Larson's Avatar
Originally Posted by mgault
Mike,
ditto - green hex head
Old 7/31/07, 8:55 PM
Unmoderated Guest
That is what you call very sloppy? At the rist of sounding narcissistic mine are a bit neater but that looks fine to me.
I have to say, here in NY that method of terminating grounds and neutrals of the same circuit is generally accepted by inspectors and MANY quality electricians do it that way. I did for many years, but do not any more.
We do NOT follow the NEC and I have had high level inspectors tell me it's fine.
Take that for what it's worth.
Old 7/31/07, 8:57 PM
Thanks for the help. So, this is alright? As long as there are not two neutral wires to one lug?
Old 7/31/07, 9:02 PM
tdietrich1's Avatar
No.
Document it.
http://www.nachi.org/forum/attachmen...2&d=1180638925
http://www.nachi.org/forum/f19/electrician-signs-off-ganged-neutrals-now-17471/
tom
P.S. Does anyone see a GEC? If it's at the Disconnect, why is there bonding here?
Old 7/31/07, 9:03 PM
That's the only call out I see... "neutrals fail to terminate at their own termnal lug"
- Mike
NACHI05040682
(843) 442-9755
Old 7/31/07, 9:46 PM
Unmoderated Guest
For the record: I understand the issue most folks have with this, but those photos are NOT the same thing. Doubling neutrals is not the same issue as in the original post.
Originally Posted by tdietrich1
Old 7/31/07, 9:51 PM
Have to quote Petey
Incorrectly spoken; 'Neutrals not terminating beneath their own terminal lug' is the call out.
They are not double lugged... Petey is correct, double lugged is different.
- Mike
NACHI05040682
(843) 442-9755
Old 7/31/07, 9:56 PM
Mike Whitt's Avatar
Unmoderated Guest
Mike,
Yea now I see it. Guess I am so blind I need to be lead to the point before I know that I am there
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
