Old 12/25/11, 2:10 AM
Default Ooops, knocked loose a breaker from the bus bar, what next?
If an inspector accidentally knocks loose a breaker from the main bus bar, what would you recommend they do? Reach into the panel and push it back into place?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/25/11, 3:13 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Re: Ooops, knocked loose a breaker from the bus bar, what next?
I would turn it off and push it back into place...
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 12/25/11, 7:11 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
This is the reason I never open a federal Pacific "stab-lok" panel.
A Federal Pacific Electric "Stab-Lok" service panel is in use. These panels and breakers are a latent hazard and can fail to trip in response to over current, leading to electrical fires. The breakers may also fail to shut off internally even if the toggle is switched to "off." Some double-pole (240-Volt) FPE circuit breakers and single-pole FPE Stab-Lok circuit breakers simply do not work safely. There are other panel-defects independent of the breaker problems, panel and panel-bus fires and arcing failures in some equipment. The failure rates for these circuit breakers were and still are significant. In some cases failure to trip occurs 60% of the time - a serious fire and electrical shock hazard. Failures are documented in the CPSC study and by independent research. Have a licensed electrician make further evaluation and corrections as needed.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/25/11, 8:00 AM
Wayne B. Wilson's Avatar
I would turn off the main , take a picture note it, recommend a electrician review panel. and put it back in , But i would leave it off with a tag. and note to home owner.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 12/25/11, 8:58 AM
KEVIN WOOD's Avatar
Just to make things clear about the Stab-lok comment. You should still put in your reports to have the "Certified Electrician" make the descision whether it is safe or not.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/25/11, 10:10 AM
Jeffrey R. Pope's Avatar
Each situation should be judged independently, but I will usually reinstall the breaker myself.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/25/11, 11:36 AM
Agreed....truly depends on the comfort level of the inspector doing the inspection.
Paul W. Abernathy
Old 12/25/11, 11:44 AM
Which depends on the gloves he's wearing!
I'm updating InterNACHI's safety course, so I have to assume lowest common denominator in what I write.
(303) 717-8940
Old 12/25/11, 12:32 PM
Dale Duffy's Avatar
Everyone should have a pair of Klein Electrical Protection Gloves.
Old 12/26/11, 8:05 AM
Garry Sorrells Garry Sorrells is offline
Please Note: Garry Sorrells is a non-member guest and is in no way affiliated with InterNACHI or its members.
Would it no be reasonable that the cover not be removed unless the person has the knowledge, ability and confidence to reinstall the breaker?
Old 12/26/11, 11:17 AM
Tim Spargo's Avatar
Nice gloves Dale...
And yes, I would judge the situation and go from there. In my case, most breakers would be replaced, if I knocked them loose and it was safe IMO to replace them.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 12/26/11, 11:22 AM
KEVIN WOOD's Avatar
I have a friend that was very knowledgeable and worked on high voltage. He lost both his arms from an electrical panel explosion; That makes no bearing on a person's confidence, some of the most foolish deaths are from the result of misinformed knowledge of safety by regular individuals.
I watched in surprise as a Seasoned Electrician re-installed a breaker falling out that was already arcing on the buss with no gloves, no glasses and no rubber soled shoes. The Real Estate Agent just looked in amazement.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/26/11, 1:51 PM
Joseph M. Whitt Joseph M. Whitt is offline
I couldn't find a voltage rating on those gloves. Do they have one?
Mike Whitt
Contractor/Instructor
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Ooops jfrederick Electrical Inspections 10 9/2/10 2:08 PM
Arching Causes Main Breaker To Trip? msylvester Electrical Inspections 10 10/22/07 3:57 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 2:05 PM
