Old 2/19/08, 6:52 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Open Ground
On my inspection today EVERY single outlet tested out with an "open ground". Several boxes I was able to pull right out of the wall, loose wires on several or wired incorrectly. I was unable to get near the main panel due to a large pool of standing water from a broken main. House is a foreclosure, so just wondering how you would write it up. I normally find a few in every house, but I just could not believe that every one was like that. Thanks guys.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/19/08, 8:28 PM
Unmoderated Guest
Default Re: Open Ground
I think you know how to write this one up. One sentence will suffice.
Here's an example:
"The electric in this house is a ****ing mess, have it checked out by a qualified electrician".
Just don't call me. OK?
Old 2/19/08, 10:07 PM
Richard L. Bennett Richard L. Bennett is offline
"All tested outlets have open grounds or wiring issues" None of the outlets should be used until the above issues are corrected. This is a safety issue"
"The main panel was not inspected. The standing water presented a safety issue. See attached picture."
rlb
Old 2/19/08, 10:25 PM
Bob Elliott's Avatar
Throw on some rubber boots you wimp.
Old 2/20/08, 9:16 AM
iniquette's Avatar
Would have needed waders it ws so deep. told him I would come back and check panel when plumber was done. Not a wimp, just wanna live.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/23/08, 8:28 PM
mjohnson6's Avatar
mjohnson6 mjohnson6 is offline
Send a message via Yahoo to mjohnson6
Please Note: mjohnson6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thumbs up Re: Open Ground
Ha Ha Ha
Thats a sure way to remove the competition!
open ground on 3 garage receptacles dnasser Electrical Inspections 14 10/30/06 5:53 PM
Ground Wires Inside a Panel mveitenhans Electrical Inspections 13 10/29/06 11:39 AM
Harmonized Ground Fault Circuit Interrupters jtedesco1 Electrical Inspections 5 3/21/06 8:48 AM
Open Ground tneumann Electrical Inspections 6 3/11/06 5:11 AM
