Marc-olivier Johnson is a non-member guest and is in no way affiliated with InterNACHI or its members.
hi im in Canada.
i live in an apartment that has 3 holes electric plugs. i was having a problem with my air conditioning. the breaker keeps shutting down everything in that room. so i bought a small 3 lights tester at my local hardware store. all the outlets on the indicator say "open-ground" except 2 outlets in the kitchen. i have a sneaking suspicion that the 2 "correct" ones are bootleg grounds(if term is incorrect i mean is not really grounded). i mentioned this to my landlord and offered to check on my neighbor's outlets with said small tester. his reaction surprised me , he basically said that i shouldn't get the neighbors involved and he'd get my apartment's electric system fixed. so basically i don't trust him. will fixing all the outlets to grounded help with my air conditioner problem? and how can u tell when someone fakes a ground problem solution to fool, the Small 3 lights tester? any help is greatly appreciated |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Your breaker is most likely tripping from too much current. This could be checked with an ampmeter.
A grounding conductor has no part in the normal operation of the circuit. |
thanks for answering, what should i do so that my air conditionner doesnt trip the breaker ?
i have tried to unplug everything and turn off all lights and still the air conditionner trips the breaker. |
And insist that any repair work to be done by a licensed electrician, and ask for a copy of the service ticket/invoice with the company name and license number. Good luck ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
