Who has a good narrative for the tester showing an open ground? Care to share?
Thanks in advance!!! George Russell George Russell Professional Inspections Austin,Texas TREC # 10215 512-296-9538 http://georgerussellprofessionalinspections.com/ http://www.facebook.com/austinhomeinspections |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Receptacles located at ******* not grounded properly. Have licensed electrician repair or replace.
I just KISS. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Thanks Jeff that is the route I took. I was just wishing I could find a more descriptive narrative explain, in better terms that I am able to come up with, why it's wrong and the ramifications thereof.
Perhaps the following may help...
"One or more open ground, three-pronged electric receptacles were found. This is a safety hazard due to the risk of shock and damage to equipment requiring a ground. A qualified electrical contractor should make repairs as necessary. Note - Most modern appliances and power tools require grounding type receptacles. Grounded circuits and receptacles are recommended in locations where such appliances and equipment will be used." Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
First question to ask is: Is this a 2 or 3 wire system. The wording is different when informing the client of the issue.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Like Jeff said kiss.
I agree...
| ground wire | mnorthrup | Electrical Inspections | 6 | 2/5/10 3:14 AM |
| ground fault outlet | Unregistered | AskNACHI.org Inspection Questions Forum | 2 | 5/11/09 11:13 PM |
| Ground testing | rbennett | Electrical Inspections | 42 | 4/18/06 10:16 PM |
