Old 3/20/08, 3:45 PM
William E. Billings William E. Billings is offline
Default Open neutral
Looking for a little information. I have found a high percentage of switch controlled receptacles with open neutral when checked with the tester. I have checked with several electrical contractor employees and find they really do not know the answer. I said this is incorrect wiring. I have checked the code book and and I believe I am correct in pointing this out.
William Billings
Billings Home Inspections LLC
Billings Inspection Services LLC
billingshomeinspections
West Palm Beach Florida
Old 3/20/08, 4:13 PM
David P. Valley's Avatar
Default Re: Open neutral
Are you finding these numerous open neutrals in one particular home or in many homes?
Open neutrals definitely need to be deferred to a licensed Electrician.
Old 3/20/08, 4:28 PM
I am finding them in many newer homes and I am concerned.
William Billings
Billings Inspections services
Old 3/20/08, 4:34 PM
William Billings
Probably want to verify against another tester, to make sure it isn't that. But David is correct that open neutrals need correction.
Larry Kage, CMI
231 929 3525
Old 3/20/08, 4:39 PM
I have checked it against two tester I have with the same results. This is one of the better line tester not the $ 10.00 one. I have checked other homes and they are ok. One of the problems in Florida is one can do electric work without a license by working under a licensed party.
Old 3/20/08, 4:48 PM
If you are finding open nuetrals in several homes, it's either a bad tester you are using or the same lousy Electrician wiring these homes.
I hardly ever find open neutrals, period.
Old 3/20/08, 4:54 PM
Was this with the switch on or off
Old 3/20/08, 5:02 PM
Greg, are you saying that when the switch is off an open neutral is ok. I am only getting the open when the switch is off. does that make a difference?
William (Bill) Billings
Billings Contracting LLC
CGC 1516427
www.billingshomeinspections.com
Old 3/20/08, 5:22 PM
Yes, it means they are switching the neutral.
Old 3/20/08, 5:40 PM
Exactly...
Larry Kage, CMI
231 929 3525
Old 3/21/08, 6:13 AM
Well that makes perfect sense.
Old 3/21/08, 8:14 AM
Banned
But does your code require that only 1/2 the duplex receptacle be switched as here in Canada (unless an energized unswitched receptacle is installed adjacent a fully switched receptacle). If 1/2 the receptacle is switched through a common neutral (grounded conductor- GC), the other 1/2 which is supposed to be energized fulltime would not be operational also. For this receptacle to perform as intended by our code, the neutral terminals would have to be split also and a second fulltime neutral installed.
Old 3/21/08, 9:02 AM
Nope Brian, not a NEC rule although some AHJs will say a switched receptacle does not fulfill 210.52 (A). It is not actually in the code that way.
Old 3/21/08, 11:08 AM
Mike Whitt's Avatar
Unmoderated Guest
Yes it is.
Old 3/21/08, 11:56 AM
Where? I don't see any reference to switched receptacles in 210.52
Panelboard neutral and grounding conductor terminations. jtedesco1 Electrical Inspections 0 1/16/08 3:16 AM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
