Why would the entire home show show an open neutral with my tester at every outlet.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
Here is the panel
Gary,
It's hard to tell for sure from the pic but the Neurtral looks like it might be loose and slightly charred at the connection. Send me a high res picture and I will see if I can get a better look. |
I was doing a remodel years ago, and all the lights in the house flicked, the drill and the saws would stop intermitently. Come to find out that the SEC had been rubbing against a tree for years and the neutral had been cut in two. Ended up adding an underground service upgrade to the project.
So the answer to your question is yes, it is possible. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Try this one.
Somewhat better.
What I see is that the white insulation is turning brown that may indicate heating at the connection. It's possible that the set screw was never properly torqued. It can go for years like that until enough oxidation builds up and produces a high resistance(impedance) Call it out for repair by a qualified electrician. The Aluminum conductors also looked discolored compared the "hot" legs of the SE at the main disconnect. |
My tester is has went bad. Dang it. Off to Lowe's
Happend during x-Mas I guess. Used it on the 23rd.
Buy two! I always carry a spare "everything" for just this reason. Ive been burned a few times in the early part of my HI by faulty equipment. Failed cameras, testers, etc. can put the skids on a good inspection.
Did you flag the grounds all made up in 2 big lugs?
It was built in 1981
| Mould inspection saves the day! | gmendes | Canadian Inspectors | 43 | 11/18/06 10:51 AM |
