Would like you opinions on adding GFCI outlets for non grounded existing outlets.
The NEC take on it is "better than nothing". If you can't get a ground there it is an option.
GFCI's can protect non grounded circuits if installed properly. I'm now waiting for one of the 'Sparky's" to explain it so that I can understand it. Thanks
More specifically, GFCIs "give some protection" to users when a ground is not present. If there is a ground fault, probably through the user, the GFCI will trip. This certainly adds a level of safety for any outlet. If 3 wire attached equipment develops a "hot" to case failure, the GFCI will trip. The thing it won't do is give your surge protector a grounding path so it won't help much on your electronics.
Does that do it for you? Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
Starting in Oct. the new GFCI's will not work without an equipment grounding conductor.
I spoke to a rep from NFPA and a rep from UL about this. |
Mike,
I believe you are correct as this ensures a better internal test function. On the comment from Gerry..lol...that's why electricians explain it fella...lol..man I hate the term sparky..lol Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
lol...do you mean what do I think of the little lightning bolt fella...lol
Yes
Gerry your answer is wrong - (Think I better check your online electrical course for errors) Small current difference between neutral and hot trips the breaker. If there is a lack of balance it must be going to ground - thus a ground fault Just a thought -- many two prong outlets are mounted in GROUNDED metal boxes. Just install the GFCI and ground it to the box. If there is enough ground wire run it up to the GFCI and take a jumper to the box. In this area of Florida one has to look to find two wire homes |
Good ghost writer
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| Properly Testing GFCI Outlets | tchristopher | Electrical Inspections | 17 | 3/17/07 12:19 PM |
| Replacing 2-prong outlets with GFCI outlets | kshepard | Electrical Inspections | 7 | 6/24/06 7:58 AM |
| GFCI Outlets w/ No Test Button - Dont Work! HELP PLEASE! | LiveAd | Electrical Inspections | 4 | 6/20/06 11:47 AM |
