Hi All,
Need some quick help with an electrical issue. One of my commercial properties had an inspection recently and the compliance officer cited the location for 29 CFR 1910.303(b)(2), specifically, "(2) Installation and use. Listed or labeled equipment shall be used or installed in accordance with any instructions included in the listing or labeling." The apparent violation involved some extension cords that had quad junction boxes attached to the end to provide temporary power. The quad boxes were the type with metal knock-outs present, and all of the original knock-outs were in place. The inspector said this was not an acceptable use for this type of box, although a box of similar material with no knock-outs, or one with screw-in knock-outs would be acceptable. Seems like a stretch to me, but the property is facing a violation of $2K for this. Anyone have supporting documentation I can use that might help contest this citation, or at least minimize the damage? Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. |
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
These (or equal) are the types of boxes that you need to use:
![]() Personally I know that this is an OSHA requirement but I don't see how it falls under the section that you've quoted unless these boxes are specifically listed for this application and the other type is not. IMO the $2000 fine is excessive for this violation. |
I agree with RM. I think part of it has to do with the durability of the stamped or welded box and also the possibility of the knockouts either falling out or contacting a live part.
Proof of compliance by the abatement date will usually reduce the fine by at least 50%.
There is a also a requirement for GFI protection for cordsets used for temporary usage. It cannot be supplied by a standard GFI receptacle.
29 CFR citation, please?
Robert - those boxes shown are to be used for temporary power cord sets? I suppose I am looking for the CFR that addresses that the boxes used in this case with the knock-outs are not listed for this use. Underwriters Laboratories UL 231 I believe addresses cord sets but I don't see a reference to the use of boxes with knock-outs. Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. |
This is probably the relevant NEC Article.
(H) Pendant Boxes. An enclosure supported by a pendant shall comply with 314.23(H)(1) or (2). (1) Flexible Cord. A box shall be supported from a multiconductor cord or cable in an approved manner that protects the conductors against strain, such as a strain-relief connector threaded into a box with a hub. |
Thanks Jim. I also found this OSHA interpretation:
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=20709 So there we are. Nothing to contest. Pay the fine. Thanks all for your input, much appreciated. Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. |
So which inspectors previously stated OSHA had no jurisdiction? This an unfortunate common belief, until they show up. Thanks for passing your experience along.
Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
By the way, it doesn't sound to me like you got a $2,000 fine for that one thing. Just because you abated the other violations during the inspection doesn't mean you don't get cited for those too. I've forgotten a lot of stuff, but I worked as a compliance officer for 4 years in the 80s. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
$2,500 - no electrical disconnect at a kitchen mixer (was hard wired, now plug-in) $2,500 - no lock-out/tag-out devices applied to disconnect. This one is an easy contest since there were no devices actively locked out during the inspection. Proper LO devices exist in the correct numbers, and there is staff on-site and trained in proper LO techniques and methods. $2,000 - The cord sets described in this post. This is a commercial building in the eastern U.S. I do not own or work for the employer, I am retained as a consultant. Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. |
In SC, back in the 80s, the easiest thing to do was to 'volunteer' to enter the "consultation program" (I think that's what it was called). You have to do the abatement and consent to "consultation inspections" but that took you completely out of the enforcement side of OSHA. Check into it.
I wouldn't waste much time trying to prove OSHA wrong. They hold all the cards and are generally right (they do that stuff for a living!). “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
We perform "Mock OSHA inspections" at these locations and follow the same protocol that OSHA would use. These are unannounced inspections and they have no idea we are visiting. Good fun for me, and good training for all involved. Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. Last edited by dredding; 7/21/10 at 10:01 PM.. |
Unsafe conditions that exist at a workplace or worksite....whether it is a "commercial building" or contractors who are working in your front yard.....fall under the jurisdiction of OSHA.
Whether it is simply the owner of the company...or twenty of his employees...at the site, if the conditions are unsafe they are subject to citations. An OSHA inspector has the right (and the duty, he will tell you) to address every unsafe act or condition that he observes in any workplace....even a fast food joint in which he is having lunch. Participation in voluntary programs has no bearing on what an OSHA inspector will do if called to the site by an employee or if he observes the condition or act on his own. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
| Washington HI licensing information from DOL | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 182 | 10/3/09 12:14 AM |
| Any code violation here? | bking | Electrical Inspections | 10 | 11/26/08 9:54 PM |
| Comment for loft stairs | rbrady | Structural Inspections | 19 | 7/20/08 3:29 AM |
| Consumer Advocacy Group Announces Opposition to Missouri HB 2057!!! | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 37 | 3/14/08 10:14 PM |
