Wondering if an outlet (recepticle) is ok wired directly from the main panel outside. My neighbor needs an outdoor outlet underneath the main panel for landscape lighting. I explained I have yet to see this. Any thoughts would be appreciated.
Ok as long as it is fed with the correct breaker, correct size cable, conduit should be used and weather proof outlet box, GFCI and... what did I forget?
He might need an enclosure for low voltage transformer too. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Yes, that's absolutely proper. The correct outdoor wiring methods would need to be used, as well as a bubble cover and GFCI protection.
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
| Subpanel wired as main panel. | jlybolt | Electrical Inspections | 15 | 5/23/07 4:10 PM |
