Old 11/4/06, 12:11 AM
Kenneth Blair Kenneth Blair is offline
Default Outlet under hose bib
This outlet was found under a hose bib. It is on a gfci circuit and is protected with an exterior weatherproof cover plate. Should this be reported or is it okay?
Old 11/4/06, 12:15 AM
Jeffrey R. Pope's Avatar
Default Re: Outlet under hose bib
I might recommend upgrading the cover, but there's nothing "code" wise that disallows this.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/4/06, 12:16 AM
It is a wet location outlet. Wet is wet.
I am still confused why people worry about these receptacles and don't question one in the kitchen next to the sink sprayer or next to the hose bibs in the laundry.
Old 11/4/06, 7:34 AM
Russel Ray's Avatar
In looking at the picture, I would also recommend removing the pressure gauge before trying to use the hose bib.
I've always wondered that myself and have found no good answer.
As an aside (thread drift), another perplexity is why we get all upset about a hairline crack in a foundation, but we have no problem with the HVAC guys coming in and simply destroying 36" of foundation so they can take their air duct through there.
Old 11/4/06, 8:06 AM
Roy D. Cooke, Sr's Avatar
Not much different the all other out side plugs . The get wet when it rains .
Roy Cooke
Old 11/4/06, 11:49 AM
Russel Ray's Avatar
Originally Posted by rcooke
Not much different than all other outside plugs . They get wet when it rains.
We're fortunate here in that even when it "rains," quite often nothing gets wet.
However, we have several different kinds of outside plugs here:
1 - GFCI
2 - GFCI-protected
3 - GFCI and weatherproofed
4 - GFCI-protected and weatherproofed
5 - 2-prong
6 - 2-prong and weatherproofed
7 - 3-prong non-GFCI
8 - 3-prong non-GFCI-protected
9 - 3-prong non-GFCI and weatherproofed
10 - 3-prong non-GFCI protected and weatherproofed
Then we also have three types of weatherproofing that I've found:
1 - protected by a tent of aluminum foil (sure wish I could find that picture right now)
2 - protected by flaps like that in the picture
3 - protected by bubble
Not all of them get wet. I've found that the tent of aluminum foil is the most effective.
Old 11/6/06, 10:32 AM
Paul W. Abernathy's Avatar
I think most do greg which is why the questions always get asked....should the HI recommend GFCI on the kitchen countertop even if it was done before code demanded it......well...SURE they should as it is a safety enhancement...
So I think quite possibly most do this and suggest it...we hope anyway !
Alas I think when you mean "why people" you are refering to the homeowner maybe....they focus so much on outside recepts being protected and do not think about the real risk in front of their nose......
Thank GOD....for the HI to step in and set the freakin homeowner straight....
Paul W. Abernathy,CMI,CPI,CME
Old 11/6/06, 5:20 PM
Is there a GFCI available for split recepticals ?
Not being smart just never seen one .
Roy
Old 11/6/06, 5:33 PM
Actually.......they do make a GFCI Receptacle and SWITCH combo....One side a switch to a light and the other side the GFCI....seen one the other day.
Old 11/6/06, 5:39 PM
Michael Larson's Avatar
I'd like to know that as well. I have split receptacles in my kitchen. I could install GFCIs in the panel I suppose.
Old 11/6/06, 5:45 PM
If it shares the Neutral.......not........if your question is do they make a GFCI that can be split.....I dont think so in that method because it would share a Neutral...if it was truly trying to be a split receptacle...
now if you have a totally ind. circuit for each.....then I dont know...I will see if I can find one that is made.......but probably the best bet would be just buy (2) GFCI Breakers for your panel and do both that way....that way their is no need for you to mess with the receptacles...
bonding main hose bib with pex Scott Schultz Electrical Inspections 5 6/22/07 12:39 AM
Hose pipe distance from outlet lprinzi Plumbing Inspections 2 10/21/06 5:20 PM
Hose pipe near exterior outlet lprinzi Electrical Inspections 9 10/19/06 2:23 PM
