Old 8/26/11, 4:56 PM
Frank L. Bartlo Frank L. Bartlo is offline
Question Outlets tested as semi-grounded with odd N-G and H-N voltages
I found several outlets in one room that tested as almost having an open ground (LED on right faintly lit up -- see pic), in a house with grounded wiring, and other outlets tested as properly grounded. The VOM, read 119V from H-N (OK), but only 23V from H to G, and 11V from H-N.
So the outlet appeared to be working for 2-prong purposes just fine, but appeared to be weakly grounded. I did a search and couldn't find any threads on this sort of thing.
First explanation that comes to mind is a poor grounding connection in the circuit, with excessive resistance. The room did appear to have been converted from 2 rooms to one big room, so amateur wiring appeared likely, with probably junctions in light fixture and/or switch enclosures. What's going on here?
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/26/11, 7:09 PM
Bruce A. King's Avatar
Default Re: Outlets tested as semi-grounded with odd N-G and H-N voltages
It takes a really good electrician to figure out the unusual symptoms.
It can be any combination of bad connections, improper bonding, current on ground conductors and even problems in a neighbors house backfeeding current through public water pipes.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 8/26/11, 7:22 PM
I'm thinking a bad connection because other outlets in the house and even the room tested as operating properly. Certainly is an unusual observation, more the sort of thing I'd expect in an older house with substandard grounding via old metal-jacketed ("BX") cable not done properly.
Old 8/26/11, 8:06 PM
Robert Meier's Avatar
Can you explain this?
Old 8/26/11, 8:47 PM
Jeffrey R. Pope's Avatar
I always report ineffective grounding when the resistance exceeds 1 ohm. I don't really care what the cause is.
Like Robert, I don't understand your voltage readings.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/26/11, 9:10 PM
Christopher Mennella Christopher Mennella is offline
Have you ruled out a faulty tester?
I carry two of these plus a SureTest just for redundancy.
Old 8/26/11, 9:19 PM
Roy D. Cooke, Sr's Avatar
Sounds like there could be some damp areas some where or it Carbon build up, dirt ect.
These cheap testers read strange things they draw so little current .they can give a voltage reading from my left hand to my right hand..... Roy
I would need to be there to figure out what is happening
Old 8/26/11, 10:11 PM
Michael R. Boyett's Avatar
If you look at the internal wiring diagram (3 neon bulbs w/ 47k resistors) of a 3-light tester then the most likely scenario is a poor, high resistance Grounding connection somewhere in that branch circuit as has been stated. I suspect the 11V was really G-N and was a typo.
Old 8/26/11, 10:33 PM
Chances are your digital voltmeter uses high impedance which may be why you're picking up small voltage readings (due to inductance). Also, as previously mentioned, there may be something adding excess resistance on the ground. It may be a bad connection or an extra long run of BX, where the shell is being used as the equip grnding condctr.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
opinions on GFCI outlets for non grounded oputlets jmerritt1 Electrical Inspections 23 5/11/06 7:22 PM
