Outside backyard of this house I inspected had a makeshift pole, holding up some cable wire that went from the alley pole to the neighbor's house. It appears to have be installed to hold the wire up in the air, as without it, it seems the cable would almost droop down to the ground. This can't be legal, is it?
Buyer is concerned that her children playing can climb and/or knock over pole. Look at pic...
Leon Slack III Certified Inspector GS & TJ Services Home Inspections Chicago and suburbs inspectors@GSandTJServices.com http://www.illinoisinspectors.com |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
looks like phone and cable tv, no power. seems like a long run.
You may want to forget legal and illegal. If it is a potential safety hazard, report that.
However, that looks like CATV...is it? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Welcome Home Inspection Services, LLC whis11 @ charter.net Lake Ann, Michigan 49650 The above post represents my personal opinion. For statements of fact or advice or my professional opinion, on this or another subject, please contact me, directly. Thnx, Jim.
Agree as just above the house you can see the real service line coming to the home. Connects on the poll at the insulator or crimped on to the main. We have the same arrangement here as all the CATV and Phone attached is way bellow the power lines.
THE RIGHT TRAK CIAQP, IAC2 Board Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq apoteyes@gmail.com Cell: 705-971-2096 Ph : 705-946-2676 |
Yes, it is cable. So...should I call it out since it is in her yard? Is it a safety issue? Or a property dispute? If property dispute, I suppose I shouldn't get involved.
Around here a simple phone call to the cable company would get it fixed. You may want to put it in your report that without the pole the cable can get damaged. Recommend the cable company be contacted to rectify.
Greg Mathias, CCHI Journeyman Carpenter Level I Thermographer Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
Certainly not a safety issue. Possibly a "nuisance," but wouldn't likely make it into my report.
| Conduit Bushing and NM Cable | gliebig | Electrical Inspections | 2 | 3/13/11 10:59 AM |
| I have a problem | cbottger | Electrical Inspections | 17 | 1/20/09 4:45 PM |
| Hey Electricians... Can you help by proofing this new course? | gromicko | Electrical Inspections | 69 | 10/15/08 6:14 AM |
