ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
check out these pics.
house built in early 1960's panels in bedroom closet almost 100% that the small box is acting as the 30 amp overcurrent for the AC. power supply to it is the double tap on the 50 amp breaker at the top right. I understand the double tap is wrong. I also understand that the white "hot" wires in the smaller box should be labeled black. Single self-tapping machine screw was holding the front cover on. Am I just looking at an issue of support/protection of the romex hanging outside the panels? Am I missing anything else? Last edited by ccbrands1; 9/5/06 at 9:54 PM.. |
how about the clothes closet problem and the working space problem
the following was from an former post by joe tedesco. __________________________________________________ _____ 240.24(D) Not in Vicinity of Easily Ignitible Material Overcurrent devices shall not be located in the vicinity of easily ignitible material, such as in clothes closets. Examples of locations where combustible materials may be stored are linen closets, paper storage closets, and clothes closets. __________________________________________________ _____ obviously my pic fits under this, but if it were original to the house (early 1960's) then what. no city inspection in this town. guess i'm on my own with documenting it as a fire hazard? |
The clothes closet language showed up in the 80s but the easily ignited materials language was there for many years before that.
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
ACK!!
Double taps @ Main OCPD?? White (neutral) going to breakers bunched Wires under One screw Missing fittings (as pointed out already) OLD cloth wire (scary) Open OCPD Knock out See first pic with panel cover on... Main panel bonding...Can't see it Red wire going to neutral buss for ......??? Sub panel neutral and ground separated....Can't tell Service panel legend marked or just hack job markings... See service panel label...can't tell if properly marked... Sloppy wiring job.. DIY'er Oh ya the closet thing too.. |
| Thanks Nick I just hate it when I'm wrong | cbottger | Miscellaneous Discussion for Inspectors | 0 | 6/9/07 2:01 PM |
| What's wrong here? | wwarner | Structural Inspections | 15 | 9/12/06 7:47 PM |
| Messy work, but is it wrong? | mtimpani | Electrical Inspections | 8 | 9/9/06 9:56 PM |
| is this really wrong | brepanshek | Plumbing Inspections | 15 | 8/12/06 2:09 PM |
| What's Wrong Here? | jtedesco1 | Inspecting HVAC Systems | 20 | 6/29/06 6:50 PM |
