What are the wires that are attached to the SEC that tuck up under the siding?
thanks Dave |
About the only thing they can (or should) be are grounding electrode conductors.
looks like someone ran some TV wires or something and wrapped them around the service messenger before running them into the house.
I just got off the phone w/ my buddy the electrician, nothing should be coming off that except the three service conductors.
Kevin Kevin M. Kenny, Sr. Kenny Home Inspections Oak Forest, Illinois 60452 Nachi #6070990 http://kennyhomeinspections.com
pdacey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like someone may have been trying to ground their cable or satellite TV to it.
Or phone or all three. |
Someone trying to steal power?
The GEC can terminate there if one chooses. It's not the most practical spot, but it is legal. The connection can be made anywhere from that point, down to the neutral/ground bar in the main panel. 250.24 Grounding Service-Supplied Alternating-Current Systems (A) System Grounding Connections A premises wiring system supplied by a grounded ac service shall have a grounding electrode conductor connected to the grounded service conductor, at each service, in accordance with 250.24(A)(1) through (A)(5). (1) General The connection shall be made at any accessible point from the load end of the service drop or service lateral to and including the terminal or bus to which the grounded service conductor is connected at the service disconnecting means. |
I was actually going more for humor than sarcasm.
It is two wires but they are both connected to the bare messenger. |
If this is going to the ground electrode it makes perfect sense from a lightning standpoint but running it under the siding sort of defeats the purpose. You are trying to keep the fire outside the house.
This is the picture from the handbook. It shows the load end of the service drop is at the service head, not the meter.
Exhibit 250.8 An AC service supplied from an overhead distribution system illustrating three accessible connection points where the grounded service conductor is connected to the grounding electrode conductor according to 250.24(A)(1). Last edited by Greg Fretwell; 9/28/06 at 1:53 AM.. |
Thank you Greg. I looked for half an hour last night for that pic online.
The words "load end" are key here. The end of the drop where the load is. The wires after the meter are the service entrance conductors. The wires ahead of the meter are the service conductors. The wire in the air is the service drop. The wires underground are the service lateral. |
In most cases the overhead service, wire belongs to the utillity company and they don't allow foreign attachments.
Bernie BW Foster Home Inspection.Inc |
| Wires ran from lugs to auxilary panels | Kevin Luce | Electrical Inspections | 7 | 9/20/07 9:24 AM |
| grounding wires | tvanvranken | Electrical Inspections | 14 | 3/16/07 7:24 AM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 11:39 AM |
| Black wires | dmacy | Electrical Inspections | 7 | 7/6/06 8:53 PM |
