Old 2/11/09, 5:36 PM
Richard M. Ross's Avatar
Richard M. Ross Richard M. Ross is offline
Send a message via Yahoo to rross2 Send a message via Skype™ to rross2
Default Oversized wire, reduced at Breaker
I ran into a situation today where the Air Handler w/heat strips was wired to a main panel 60 amp breaker with over sized #1 aluminum braided wire. Several of the aluminum braids were cut back (see attachment) to allow the wire to seat into the 60 amp breaker. Aside from the bare wires extending from the breaker, is this allowed?
Thank you,
Richard Ross
Accurate Home Inspections of America, LLC
Cape Coral, FL 33914
239-271-8499 Office
239-271-8499 Mobile
407-358-5376 FAX
Old 2/11/09, 5:37 PM
Default Re: Oversized wire, reduced at Breaker
No, it is not.
Larry Kage, CMI
231 929 3525
Old 2/11/09, 5:52 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
No way!!!!
Old 2/11/09, 6:02 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Nope.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/11/09, 6:10 PM
jkogel jkogel is offline
Check this link. "NSI Polaris Bug" is what Marc Shunk calls them, and that's how I found this webpage.
http://www.tork.com/electrical/productdetail.aspx
Used to connect large diam conductors or in this case, reduce the size to something that will fit the breaker correctly.
John Kogel
www.allsafehome.ca
Old 2/11/09, 9:26 PM
Thanks for your responses
Richard Ross
239-271-8499 Office
239-271-8499 Mobile
407-358-5376 FAX
Old 2/11/09, 9:31 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Old 2/11/09, 10:26 PM
iniquette's Avatar
Originally Posted by rnewland View Post
Would that be a NOOOOOOOOOOOOOOO Robert?
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/11/09, 11:10 PM
That it is, LOL
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 2/14/09, 8:37 AM
Bob Electric Bob Electric is offline
Please Note: Bob Electric is a non-member guest and is in no way affiliated with InterNACHI or its members.
No Haircuts?
Old 2/16/09, 5:59 PM
(A) Terminals.
Connection of conductors to terminal parts
shall ensure a thoroughly good connection without damaging
the conductors and shall be made by means of pressure
connectors (including set-screw type), solder lugs, or
splices to flexible leads. Connection by means of wirebinding
screws or studs and nuts that have upturned lugs or
the equivalent shall be permitted for 10 AWG or smaller
conductors.
Terminals for more than one conductor and terminals
used to connect aluminum shall be so identified.
Also...Conductors need to be protected at their ampacity and once the fella cut them strands he has altered the ampacity rating of that conductor. So as everyone says...it's a no-no that you see alot-alot...so we fail-fail it alot-alot....
Paul W. Abernathy
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Ground wire in neutral bar, neutral to breaker, hot to ground? rmc3inspection Electrical Inspections 4 8/1/06 9:44 AM
wire gauge / breaker rating jweinberg Electrical Inspections 19 7/16/06 4:36 PM
