I did a new construction inspection 2 days ago, and there was paint all over the interior of each box.
Does anyone know if this is a have any violation and have information I could borrow? Peter |
| Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
dwilliams9 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've never seen new construction that didn't have paint in the boxes. No violation as far as I', concerned. Surprised it's not full of drywall mud as well.
If you can't distinguish white from black from red, then it's a problem. Perhaps you could scratch the paint and tell the color of the conductors, though. As long as you can figure out the colors of the wires, then it should be OK.
just the way it is Pete.....
I always wonder about that question ,but I guess it is not ok to have over spray in main panel because the breaker sparks may ignite flammable material , which paint, is.
In the junction box it is assumed the wire caps are in place with twisted wires ,so there is no chance of sparking. If that is the case I still worry if the outlet is not on AFCI because with no paint inside the box I personally think the chances of a spark igniting something flammable are much far less. Nothing is perfect, and it is common sense that outlets have shorts with no harm, other than a tripped breaker and a smoke mark, most of the time ,thank goodness. |
NEC 110.12(C) is about the closest you will get.
(C) Integrity of Electrical Equipment and Connections. Internal parts of electrical equipment, including busbars, corrosion, chemical action, or overheating.wiring terminals, insulators, and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners, abrasives, or corrosive residues. There shall be no damaged parts that may adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; or deteriorated by FWIW the paint can be removed by scraping with a fingernail. |
I am with Bob on this one, The paint could ignite or make the box burn faster because it is flammable. When we install new main service panels, The black plywood that is installed behind the panel is sprayed with a special non-ignitable paint. We buy these sheets of plywood at an electrical supplyhouse. For almost 15 years, I would go to home depot and buy a sheet of 3/4 plywood for 13 bucks and cut it up into 4-2x4 sections and spray it with my own paint until this code came out. And the reason why I just can't buy non flammable paint is that their is a sticker on the plywood that I buy from the supplyhouse saying that it complies with code. And the elect inspectors in N.J. would make me send them the UL rating on the can of paint to make sure it complies.Too much of a hassle. Sorry to get off subject. Rick
rsummers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey at least they didn't fill the boxes with drywall mud
yeah....I would not loose any sleep over the condition you have shown as it pertains to the switch boxes as you have shown here. Now a panelboard and panel enclosure...we got issues...a little spay in a switch box I would not worry about it as long as the conductors are clearly identified.
Paul W. Abernathy |
Most interior paint is latex, is water based and therefore isn't "flammable". Far less "flammable" than the wire nuts or plastic sheathing on the conductors themselves.
Gotta give you that one. so breaker overspray is OK too ? Might become the new fad as insulation. |
Overspray on the bus bars is a different issue, which can affect the conductivity of the metal at the breaker to bus connection, creating resistance and excess heat.
Would that be what you mean? |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 2:00 PM |
| Electrical Inzpections | jtedesco1 | Electrical Inspections | 9 | 9/14/08 9:14 AM |
