Ron Waller is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does a 200 amp main panel ever have more than 100 amps in each leg of a balanced feed?
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
How about 105A on each leg which should not trip the main
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 11/1/11 at 10:09 PM.. |
Constant load I think 160 amps . been out of the trade too many years but I think it is 80% . I expect some one might add to this thanks .. Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 11/1/11 at 8:01 PM.. |
Robert your response does not even make sense!
How about 105A on each leg which main not trip the main THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I am not an electrician but I remember 75% but I am not sure. I hope that someone can clarify this, it would be nice to know if it has changed.
Roy I think you meant to say over 100/leg. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
( " Panel board capacity Does a 200 amp main panel ever have more than 100 amps in each leg of a balanced feed? ") Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
OK we went from 100/leg to 200/leg so your last comment says 160 constant load. So I need more clarification if you can Roy.
Does a 200 amp main panel ever have more than 100 amps in each leg of a balanced feed? ") And the answer a 200 amp panel is 200 amps on each leg the Constant load is 80% , I was wrong at 70% . You can over load a breaker for a short period like motor starting so yes it can exceed 200 amps per leg but a breaker should eventually dump at over 80% of rated load . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
At 240 volts a 200 amp panel will have a capacity of 200 amps of load. At 120 volts the same panel will have a capacity of 400 amps. A full 200 amp, 240 volt load might take a long time to trip the 200 amp OCPD if at all. A continuous load is one that will continue for 3 hours or more at maximum ampacity. Continuously loaded circuits and feeders must be sized at 125% of the connected load.
Thanks Robert M and Roy. I think that has now been cleared up.
Sized at 125% for motors 80% over rated 200 Amps/leg and it will trip the main. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Not sure what you mean by this? Are you saying >160 amps will trip the 200 amp OCPD?
I made no comment about 160 amps that is Roys.
He asked if there can be more than 100A per leg, and the simple answer is yes. An example is 105A per leg. Each leg of a typical 200A 120/240V panel should have a 200A capacity.
Circuits and feeders should only be loaded to about 80% of the rating (wire sized for 125% of the load), but that load would likely never trip a breaker. Loads need to be in the range of about 100% to 130% of breaker rating to trip a breaker. Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 11/3/11 at 4:32 PM.. |
Unless of course if you are dealing with Federal Pacific but that is a whole new topic. LOL
Do you have any evidence to show that I am wrong . I do have a FP in my home and see these in many homes . They are still being installed in Canada. Thanks ... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Panel board I have not seen before | belliott | Electrical Inspections | 7 | 5/4/10 2:46 PM |
| Main panel...recommendation ? | dnasser | Electrical Inspections | 6 | 11/22/09 9:55 PM |
| NH licensing | prussell | Legislation, Licensing & Legal Issues for Inspectors | 12 | 5/21/08 4:40 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Need help with main panel board buss bar | smcintire | Electrical Inspections | 63 | 1/8/08 5:55 PM |
