| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
I recently did a H.I. and while putting the over sized cover back on got a numbing shock, any similar experiences?
Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com |
____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
The open ground that i got while testing, should have been a clue.
that is how the panel was installed the breakers do say off at the top and on at the bottom of the breakers Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com |
Hmmm, where's the neutral feed? ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
That panel, is a complete "amature night" job and is clearly in a dangerous condition, I'd just defer the whole mess to a licensed electrician.
BTW Amy, please go to home depot and pick up a voltage "tic" so you can sense for stray voltage on any panel before it gets to bite you!! Regards Gerry Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience. Adam Smith (1723-1790) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106
![]() Agree on where is the neutral. Tried blowing up your photo and couldn't tell if the main feed had a dust mark or a nick in the wire at the edge of the panel. Bobby Hamilton Bloodhound Home Investigations Youngstown Home Inspection Austintown Ohio Home Inspection Youngstown Home Inspector Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Thats a dust mark, I noticed that too.
I did recommend that they get a qualified Electrian in to look at this panel box. I had the home owner Phone me, and say to me that he phoned an electrian and he described the box to him. I explained to him that descibing electrical over the phone is like me telling you how to give your wife a hair cut.(both dangerous things to do) I told him that I would only sign off on this box, having been looked at and fixed by a qualified Electrian when I have seen the paper work. Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com Last edited by aerb; 7/14/08 at 11:39 PM.. |
"home depot and pick up a voltage "tic".
thanks for the tip, Gerry, I will. Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com Last edited by aerb; 7/14/08 at 11:09 PM.. |
looks like they used a bare conductor for the neutral/ground.
2 q's...
1) where was the bonding screw/strap located? 2) what were you touching other than the panel cover? |
Since the neutral was not insulated and in contact with the case current could flow through anything conductive.
And as others have said the breaker slots on half the panel should not have been utilized. In the US "up" should be "on" according to the NEc. |
ccurrins is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Electrical for Dummies | mcyr | Electrical | 16 | 6/9/08 10:59 PM |
| National Electrical Code Information and Discussion | jtedesco1 | Electrical | 44 | 4/18/08 12:43 AM |
| Panel Inspection Safety | roconnor | Electrical | 10 | 9/24/06 10:02 PM |
| Bad electrical problem | Pest Guy | Electrical | 4 | 1/20/06 10:26 PM |
