Would the sump pit cover qualify as sufficient flooring to meet clearance requirements?
| Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No. If you are inspecting to code you would need 3' clear space in front.You would also need the clear space 30" wide.
David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
I know that. But how could this be corrected without relocating panel or pump? Home built in 1983.
IMO it cannot be done. One or the other must go somewhere else.
A picture is worth a 1000 words
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I think we all know that the sump pit and/or the electrical panel isn't going to be moved. So, report it as you see it and move on. Now, off the record, if this was in my home, I would install a solid, rigid (preferably steel) cover plate and bolt it to the floor. This would satisfy my need for safety, and still allow access to the pit for maintenance. Really, how often does one go to their breaker panel anymore, let alone needing repairs in it? Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
If the home built before the 1980's only 2.5 feet was required. www.MauiHomeInspections.com |
Thanks for the replies. I new there wasn't much that can be done. Just curious how others would report the safety issue. I reported like Jeff has said. I mentioned it but not as a defect in the summary.
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
And nobody sees a problem with the sump pit discharging into the sewer?
Big problem.
Is this a grinder pump, or a sump pump? Grinders go to main sewer; sumps should go to outside the home. What is that pipe on the left from?
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
Look like a sewer ejector pump to me. A sump pump would normally have only one pipe.
The black (ABS) pipe is a vent pipe, it drains outside at left side.
Ok....based on the angle of the picture the pump itself may not be in the 30 inch wide working space...but the vent pipe to the left is....simpy reroute the vent pipe to the right, up and over...
Only needs 30 inches for panel width space and 36 in front.....re-route some pipes....unless ofcourse this is my optical illusion. Paul W. Abernathy |
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
