![]() Besides the gauge wire undersized how would you write up this jumper? This is a 200 Amp sub panel commercial. |
| Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
3 phase Panel Needs immediate replace with Correct Panel .
Recommended Upgrade by qualified person Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 8/21/11 at 2:18 PM.. |
The 3 phase panel would be common in a commercial setting. The supply seems to only be two hot legs instead of three. This may be a three phase panel being used in a single phase setup. To avoid 1/3 of the panel being dead someone added the jumper to supply power to the 3rd leg.
While the 2 conductors in the lug is improper, it is hard to make any other assumptions as to what is happening. The ground wire to the can may also be using a screw that does not have the 2 threads of engagement required. |
| Main panel...recommendation ? | dnasser | Electrical Inspections | 6 | 11/22/09 9:55 PM |
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
| Subpanel wired as main panel. | jlybolt | Electrical Inspections | 15 | 5/23/07 4:10 PM |
