Old 1/25/11, 6:00 PM
David C. Macy's Avatar
Default panel enclosures being used as junction boxes
When a panel enclosure is used for a junction box is the enclosure required to be sealed properly. Many times I see a screw inserted at the openable part of the cover and many times there is none and the cover is open. I would think it would be the same requirment for a junction box but just thought I would ask.
I noted the knob & tube, open knock outs and was just asking about the enclosure/covers.
panel-enclosures-being-used-junction-boxes-1761111-088.jpg   panel-enclosures-being-used-junction-boxes-1761111-075.jpg
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/25/11, 6:07 PM
Robert Meier's Avatar
Default Re: panel enclosures being used as junction boxes
The cabinet cover should be sufficient to close the box. They do manufacture listed boxes with hinged covers.
Old 1/25/11, 6:12 PM
Would these pictured boxes be acceptable for this application?
Old 1/25/11, 6:34 PM
Jeffrey R. Pope's Avatar
The boxes with covers are fine, as long as they snap shut. If the cover does not latch, it's no good.
The panel on the right (in your second picture) should be sealed. The openings in the cover are no good.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/26/11, 9:21 AM
Joe Funderburk, CMI's Avatar
Panel in photo 1 has an open knockout.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/1/11, 5:34 PM
jcundiff's Avatar
jcundiff jcundiff is offline
Please Note: jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi David-
We do see alot of these in our area- especially in those sub-panels located in the basement stairways- 1940's 50's bungalows and ranches in Parma, Seven Hills etc. Most AHJ's accept this practice, though it must be said that is indeed a modification of a listed enclosure. So, a closed minded AHJ might balk. I've seen a good number of them with the door screwed shut with a single sheet metal screw with the tip blunted. I think if I would have come across it when I was in code enforcement, I would have asked that the old furnace disconnect be yanked and the conductors incorporated into the larger box.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 1:18 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
