Old 6/11/10, 9:44 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Default Panel question at REO inspection today
Looking for feedback. See any issues? Other than the opening in the picture with the cover installed. I'm curious about the 14GA wire feeding the double 20A breakers near the bottom, marked pool filter. There was no GFCI (or disconnect at all) near the pool equipment.
panel-question-reo-inspection-today-pict0110.jpg   panel-question-reo-inspection-today-pict0111.jpg   panel-question-reo-inspection-today-pict0113.jpg
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/12/10, 8:30 AM
wsiegel wsiegel is online now
Default Re: Panel question at REO inspection today
# 14 in on a 20 amp breaker is wrong. Also looks like you have two neutrals under one screw. Are those multiple aluminum grounds all under one screw??
Old 6/12/10, 9:18 AM
Robert Meier's Avatar
There was a period of time when GFCI protection was not required for hardwired pool pump motor's. This requirement was reinstated in the 2008 NEC. Also I believe that a hardwired pump may have an OCPD larger than the conductor size due to starting current compensation, as with other motors covered under Article 430 of the NEC. A thermally protected pump would use the OCPD to provided short circuit and ground fault protection, but not overload protection.
Old 6/12/10, 9:30 AM
Jim Port Jim Port is offline
Unmoderated Guest
Thanks for thinking the same thing I was about the conductors to the motor load. I scanned this and then got some coffee while I thought about this and you posted in the mean time.
Old 6/12/10, 9:35 AM
Sure looks that way in the picture, but I looked specifically for that condition and didn't find any.
Yes.
Darin Redding, CPI
Facebook Like
619-663-8740
Main panel...recommendation ? dnasser Electrical Inspections 6 11/22/09 9:55 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Panel Surround / Exposed Wiring Question thance Electrical Inspections 11 2/19/08 9:06 PM
Panel Question thejnicki Electrical Inspections 18 10/7/06 1:07 PM
