Old 3/12/10, 12:28 PM
Kenny Rigler Kenny Rigler is offline
Default Panel Questions
This is a Cutler Hammer panel. Two questions:
1. Are these breakers rated for double-taps (third breaker up in pic)?
2. Is that an aluminum conductor or tinned copper (fifth breaker up in pic)? How can you tell a difference?
Thanks.
Kenny
panel-questions-img_4353.jpg   panel-questions-img_4356.jpg   panel-questions-img_4348.jpg   panel-questions-img_4350.jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/12/10, 12:37 PM
Jeffrey R. Pope's Avatar
Default Re: Panel Questions
This appears to the CH panel that allows two conductors per breaker-terminal.
It looks like AL.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/12/10, 1:12 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Is that a burn mark (below lower left of main breaker)?
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 3/12/10, 2:44 PM
Thanks Jeff.
Robert, I'm not sure what that is. Here's the only other shot that I have of it...any thoughts?
I was already going to recommend further review due to the doubling up of ungrounded and grounded conductors...but will also add it to the list along with the potential AL conductor.
Kenny
Hays, KS 67601
785-656-0272
Old 3/12/10, 4:45 PM
Thomas Jansson's Avatar
Thomas Jansson Thomas Jansson is offline
Is AL wiring a concern when it's serving a heavy appliance, like an electric range or a water heater?
SOP requires disclosure of solid AL branch circuit wiring.
So, what about 10awg and larger stranded AL?
Tom Jansson, Owner/Inspector
Acuity Home Inspection Services
Old 3/12/10, 6:01 PM
Jeffrey R. Jonas's Avatar
Stranded is fine. It's the solid that has issues.
Old 3/12/10, 9:10 PM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
No "w" type seizure screw for circuit wires.....I would recommend further evaluation to confirm that two circuits were allowed on this type of ocpd.
Old 3/13/10, 11:10 AM
gbeaumont's Avatar
Thanks.
Kenny
I don't believe that breaker is rated for 2 conductors, in the rated braker you can't see the conductors, and the silver conductor is certainly aluminum (you'll never see tinned copper in thermoplastic insulation)
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 3/14/10, 8:12 AM
Gerry is correct....Tinned copper will have a rubberized insulation and AL will have the thermoplastic.
Paul W. Abernathy
Question Regarding Panel jevans Electrical Inspections 11 8/12/09 7:31 PM
100 amp Service w/new 200 amp panel mlong Electrical Inspections 10 2/7/08 2:08 AM
Newbie panel questions bracine Electrical Inspections 6 1/22/07 11:17 PM
White Wire to Breaker and Splice Inside Panel maitai11 Electrical Inspections 31 9/5/06 11:09 PM
