Old 1/31/09, 3:45 PM
David C. Macy's Avatar
Default Panel wiring question
Home has a 200 amp FPE main panel. There were a few concerns with the main panel as it was an FPE, had open cover knockout at cover, double tap, low voltage transformer in panel, open knock outs and over crowded wiring and a few other issues as well.
There was a 100 amp sub panel connected and what I have never seen before is they connected all the neutral ground connections in the main and just ran the hot to the sub breakers. One reason for the over crowded wiring. The had all the neutrals and grounds separated in the main.
I referred both panels to a sparky as I would replace the FPE and leave it to the electrician if he is going to use the sub or just add one larger main panel box.
What are your thoughts on the wiring to the sub panel? Is blue an acceptable wire color to use?
ID:	26597   panel-wiring-question-131709-080-small-.jpg.jpg
ID:	26598   panel-wiring-question-131709-087-small-.jpg.jpg
Old 1/31/09, 4:14 PM
Joe Funderburk, CMI's Avatar
Default Re: Panel wiring question
As far as the FPE panel,
"The FPE Stab-Lok panel is considered a safety hazard. Hazards associated with this manufacturer have been documented by industry experts. A high percentage of FPE Stab-Lok breakers have failed to open under over-current conditions. Replacement is advised for safety reasons. At the minimum, the panel should be thoroughly inspected and deemed acceptable by a competent licensed electrician familiar with this type of panel . (See http://www.aohomeinspection.com/resources.htm and other documents for details of hazards.)"
Done.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
Old 1/31/09, 4:26 PM
Michael Larson's Avatar
Working link HERE
Michael Larson
Hudson, WI
Old 1/31/09, 4:29 PM
Do you guys actually read the freaking question/post. I know about the FPE. Thats not waht I asked about.
Old 1/31/09, 4:32 PM
My apolgies David. I did not read to the end.
There is no problem with the blue wire and wire nuts in the panel.
Light blue does happen to be the color reserved for "earthed conductor" in Europe but your not there.
Michael Larson
Hudson, WI
Old 1/31/09, 4:35 PM
Thanks
Why would they make all the connections in the main? Seems way overcrowded.
Old 1/31/09, 4:39 PM
Thanks
Looking at the old cloth wiring on the right, I assume that the FPE panel is not original to the home.
Pretty typical to extend those old wire runs in that manner.
Michael Larson
Hudson, WI
Old 1/31/09, 4:44 PM
Bob Elliott's Avatar
Is that exposed wire coming out of the 2nd and third 20 amper from the top left side?
Looks like someone just sniped off the conductors.
Old 1/31/09, 4:48 PM
Yes they were sniped away. FPE panel would be original. House is 25 years old.
Old 1/31/09, 8:46 PM
...What are your thoughts on the wiring to the sub panel? Is blue an acceptable wire color to use?
My notes to myself in my language.
Color Function
Black: Hot wire
Red: Hot wire
Blue: Hot wire
White code black: Hot wire
White: Neutral wire
Green : Grounding wire
Green and yellow: Grounding wire
Bare copper: Grounding wire
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/31/09, 8:47 PM
Thanks
OK, you referred the main to Sparky because it was an FPE. Who cares about the crowding issue. If they replace it, as I assume you recommend, the issue of overcrowding is not an issue.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/1/09, 12:34 PM
Marc D. Shunk's Avatar
Banned
You betcha. Any color but green or white is fair game to use as a hot conductor.
The crowding is not even remotely close to being a problem. You're allowed 75% gutter fill, which is loosely defined as the number of conductors you can bash back in there with the butt of your hammer and still get the cover on.
Old 2/2/09, 8:38 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
That gave me a chuckle!
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Sub panel question smcintire Electrical Inspections 9 7/13/08 12:55 AM
Panel Question rnewman1 Electrical Inspections 2 12/13/07 2:01 PM
Panel Question gmckenzie Electrical Inspections 9 8/24/07 1:25 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
