Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
LinkBack Thread Tools Display Modes
Old 2/28/06, 6:55 AM
jtedesco1 is considered disreputable jtedesco1 is considered disreputable jtedesco1 is considered disreputable
Default Panels of all types found around the USA!
Found in a bathroom of a 1920's house in East Los Angeles... Installed by the homeowners "friend"..... Fed from a 35A "multibreaker" The cloth wire attached to the ground bus & exiting the screw hole in the back of the can goes under the house & "wraps" around a steel water line
The burn marks were caused by a torch when the wires were soldered. This equipment was found in Nebraska in a refrigerator that served as the cabinet for this "Home Made" Panelboard!
And, as if this wasn't bad 'nuff, the seller is a Journeyman Electrician!
This great little loadcenter was the supply for an above ground spa.
It was mounted about 18" above the ground in a flowerbed, where it was watered regularly.
The cover was nowhere to be found.
This was what was running the sprinkler system until about a week before they put the house on the market.
Old 3/1/06, 12:41 AM
William J. Decker's Avatar
William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information William J. Decker is very trusted source of information
Default Re: Panels of all types found around the USA!
Brilliant Joe!!!
"Think of it as evolutionin action."
"Stupid people die in stupid ways."
Will Decker
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 3/1/06, 10:11 AM
Paul W. Abernathy
This message has been deleted by pabernathy. Reason: Pointless.....
Old 3/1/06, 10:23 AM
These images are on the old board and I did not write the part about the electrician.
I believe Harvey was the Inspector on this job.
Old 3/1/06, 10:27 AM
Paul W. Abernathy
This message has been deleted by pabernathy. Reason: Again....Pointless
Old 1/6/07, 12:25 AM
The X-Files have nothing on these. Our Y-Files are Code Violations so obvious they are almost comical. (But they are not) Electrical Safety is not something to take lightly .... With that said, here we will present the Best of the Best (?) in Electrical Code Violations.
What are Y-Files? We call them that because, when you see them, the first thing that comes to mind is Y (Why) would they do this? and What were they thinking???
If you would like to send us a Photo for our Forum, please do. Send your digital Photo in any common format to: Photos@Electrical-Contractor.net please include a description and contact info. If you wish to remain Anonymous, make sure to let us know.
Photo courtesy of: JOE TEDESCO
Old 1/6/07, 12:39 AM
bandag bandag is offline
bandag hasn't had much positive or negative feedback
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can't believe that guy "made" his own panel, he should have made a casket for himself while he was at it.
Old 1/10/08, 7:03 AM
Bump, note the date, still worth discussing again.
Old 1/11/08, 8:11 PM
Chris D. Duphily's Avatar
Chris D. Duphily Chris D. Duphily is online now
Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information Chris D. Duphily is very trusted source of information
Originally Posted by wdecker
Brilliant Joe!!!
Well said!
Joe- feel free to add this one to your trophy case
As always All photos I post are free to be used by any member NACHI.
Main Panel transformed to a junction box as I called it out as a safety hazard (wet location, improperly supported)- this was the "repair" made by an electrician.
A2Z Home Inspections
Chris Duphily
RR 1 Box 1107
Dingmans Ferry, PA 18328
Office: 570-371-6696
NACHI06092689
Proudly serving: Stroudsburg PA,Dingmans Ferry PA, Scranton PA and all of: Monroe,Pike,Wayne,lackawanna counties
http://www.a2zpa.com
http://www.a2zpainspections.com
Vice President - Pocono-Northeast PA Chapter of NACHI
Old 1/11/08, 8:26 PM
Originally Posted by cduphily
Well said!
Will do!
I will use it. Please post the picture from the rain site too showing the panels.
Display Modes
Distribution panels bking Electrical 2 3/11/07 11:29 AM
Electric Radiant Ceiling Panels bbernier Canadian Inspectors 4 2/15/07 2:22 PM
FPE Panel - Do you open them up? menser Electrical 11 2/7/06 7:31 PM
Old electrical panels? ysoltis Electrical 0 1/13/06 12:38 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
