Old 9/25/06, 2:01 PM
gmathias gmathias is offline
Please Note: gmathias is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Paper tags inside the panel !!?
I opened a 100 amp distribution panel to find paper tags attached to conductors with string. I've never seen this before, but I don't like the idea. I'm telling the client to have them removed, but am I supported by any documentation?
Old 9/25/06, 2:13 PM
nwagner's Avatar
nwagner nwagner is offline
Default Re: Paper tags inside the panel !!?
You're definately supported by common sense. I'll leave the NEC referencing the regulars...
Old 9/25/06, 2:44 PM
Thanks
Old 9/25/06, 3:32 PM
Unmoderated Guest
That is very common with panels of that era. I think for the small amount of paper present there is no problem with it.
I think a lot of the more "commercial" guys did that back in the day.
Hey, at least the circuits are identified.
Also, that panel is extremely clean. The wiring could be straightened up a bit, but the panel itself is spotelss.
**Edit- Looking back at the pic I think the panel is newer than I originally thought. Must have been an old timer who did it. No one uses those tags any more.
**second edit- typo**
Old 9/25/06, 5:46 PM
Double tapped Neutrals.
Old 9/25/06, 5:59 PM
dchew dchew is offline
The big question is does it pose an electrical or safety problem. Personally, I wouldn't call it out. Normally, what I see is that electricans use scrap pieces of the romex exterioral shealthing to label the individuall cable runs.
Old 9/25/06, 8:38 PM
Jeffrey R. Pope's Avatar
You could say that, but I'd disagree.
These paper tags are certainly not "listed components." At the very least, should be reported as such, whether you feel they pose a hazard or not.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/25/06, 8:50 PM
Unmoderated Guest
Jeff, we are typically on the same page but I gotta part with you here.
There is no restriction as to how much sheathing we leave on NM cable inside the panel. Only a minimum length.
There is quite a bit of paper in NM cable and I have seen some guys leave 6"+ sheathing so they can write on it.
That is no less of an issue than we have here.
You guys would really put this in a report?
Old 9/25/06, 9:04 PM
I understand where you're coming from Pete, but this is one of those situations (again) where the electrical "expert" has the latitude to call this "acceptable," where (IMHO) the HI does not.
The paper inside NM is part of a listed component, these tags are not.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/25/06, 9:11 PM
Roy D. Cooke, Sr's Avatar
I agree I would not even consider calling this .
How many cables have we put on tags and plasic markers .
Most control panels have lots of prints left in them.
Roy Cooke
Old 9/25/06, 9:18 PM
I wouldn't.
Larry Kage, CMI
231 929 3525
Old 9/25/06, 9:25 PM
Andrew Shick's Avatar
Andrew Shick Andrew Shick is offline
Nope.
Old 9/25/06, 9:29 PM
Michael Larson's Avatar
No, I wouldn't.
Sorry Jeff we just don't see eye to eye on this one.
Old 9/25/06, 11:15 PM
Thanks for your "spirited" input. I understand (I think) the black and white of this. I've suggested that they have the paper tags removed as the breakers are labeled on the inside of the panel cover door.
Old 9/27/06, 10:39 PM
I've been in Vegas and haven't been visiting the board much
Originally Posted by mlarson
No, I wouldn't.
That's okay.
This condition would not warrant a "needed" correction necessarily, but I wouldn't consider it a "non-issue."
At the very least, I would have reported the presence of the tags. After that, I'm not sure where I would have gone with it.
Jeff Pope
Santa Clarita CA
(661) 212-0738
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Service panel full of paper tags gwilcox Electrical Inspections 5 8/17/07 6:55 AM
Ground Wires Inside a Panel mveitenhans Electrical Inspections 13 10/29/06 11:39 AM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
