Old 7/15/10, 12:34 AM
Joe Funderburk, CMI's Avatar
Question Pigtail splice in the main panel
Can you do this? Two conductors were pig-tailed together and inserted into one leg of a double-pole breaker. How is this different from double-tapping?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/15/10, 1:07 AM
Default Re: Pigtail splice in the main panel
If it was a single pole breaker, there would be no problem. However, the two-pole breaker should be dedicated for whatever appliance (most likely a dryer) it protects. There shouldn't be a 120V circuit created from one leg of the two-pole.
If the condition was involving a single-pole breaker....Splicing the conductor isn't considered double-tapping since the two conductors aren't brought under the one lug. The problem is when the lug is not rated for two wires...possible arcing and overheating may occur. Since the two wires are pigtailed with one wire going under the lug, there isn't an issue of a possible bad connection. The wires will still be protected properly by the OCPD. Basically it's the same thing if the wires were spliced in a junction box down the run.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 7/15/10, 1:15 AM
Bob Elliott's Avatar
Could be a heater and A/C which are never on together.
Double tapping is wrong because of possible sparking from a loose screw.
I notice they have the breaker in off position and also so corrosion going on at the lower conductor..
Old 7/15/10, 10:16 AM
wnapier's Avatar
wnapier wnapier is offline
Please Note: wnapier is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a related question, something I've wondered about for sometime.
If one is pigtailing wires (something I've done once or twice myself over the years) should the last length going to the breaker be upsized from what the other two pigtailed conductor wire sizes are?
Though I doubt it would ever happen (without the breaker tripping first) it would seem that the last run could almost act like a fusible link in certain situations unless it were larger.
At least that is what I've done. Overkill and unnecessary, huh?
Al in TN
Old 7/15/10, 10:52 AM
There's no need to increase the size of the pigtail connecting to the breaker as long as the conductor was properly sized to begin with. The breaker will still trip at it's proper rating even though there are two separate conductors being run. Yes the amperage may differ going through each conductor, but the total combined will not go over the rating of the breaker.
Jeff
Jeff Wicklander
Old 7/15/10, 10:56 AM
wnapier's Avatar
Thanks Jeff, pretty much what I figured but wanted to hear it from someone else.
Still OK to do if it makes one feel better though, right?
Al in TN
Old 7/15/10, 12:07 PM
Chuck Evans's Avatar
I've never seen that kind of splice used in a panel. It looks like an automotive type clamp on tap. If this is an approved device could someone please provide some more info on it?
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 7/15/10, 1:07 PM
It's a type of 'Suitcase' used to make splices without stripping. UL listed
Jeff
Jeff Wicklander
Old 7/15/10, 2:01 PM
Humberto Carvajal's Avatar
Humberto Carvajal Humberto Carvajal is online now
Those connectors are often used in lighting fixtures. At least that's where I usually come across them.
Bert
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Old 7/15/10, 7:30 PM
James A. Levy's Avatar
James A. Levy James A. Levy is online now
Bert
Yes, would much rather see a wire nut, but suitcases can do the job. They are primarily a lighting connector though.
Old 7/20/10, 12:09 AM
Jeff
Thanks - I have never seen one in use in the thousands of panels I've inspected. Now when I do, I won't have to ask.
Houston, TX
Main panel size scroenne Electrical Inspections 4 4/24/10 1:11 PM
Main and Sub Panel gheller Electrical Inspections 10 9/25/08 9:22 PM
Noisy (Buzzing) Main Service Panel thance Electrical Inspections 1 1/6/08 8:45 AM
Disconnect and Main panel srowe Electrical Inspections 10 6/13/06 7:49 PM
