Is it acceptable to pigtail a copper wire to an aluminum 2 AWG SE cable? I came across a 100 AMP panel yesterday that was recently replaced and looked OK, with the exception of the this copper splice (pigtail) inside the panel. One side of the SE cable was aluminum and the other was pigtailed with a 12 inch section of copper.
Thanks, Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared Thermographer®, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
It may be okay.
The conductor(s) need to be sized properly, the connector needs to be listed for CU/AL connections and it should include an antioxidant paste. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
they even have a purple wire nut exclusively for that type of pigtailing.
Thanks, Guys!!
I kinda thought it was OK, but wanted a second opinion. Thanks, Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared Thermographer®, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
A connection like that should have all of the items listed, but you should not be able to see them. The mechanical portion should be a split bolt, or an approved set screw connector. Then it is usually wrapped with a rubber insulating tape and then vinyl tape for protection. I have never seen a wire nut that was large enough for the connection you describe.
Polaris Splices- Easy method and CU/AL Rated are a good choice as well.
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
