Would you be OK with a ceiling fan hanging from a plastic box like this? A plastic ceiling fan box is a new one on me. I'm worried about fatigue and material failure down the road.
![]() According to NEC 314.27 a ceiling fan box should be "listed, marked by the manufacturer as suitable for this purpose....The required marking shall include the maximum weight to be supported." I can't find any of that on the product itself. I'm not sure that simply saying "UL 514C listed" on the packaging and website is OK. http://www.hubbellcatalog.com/raco/R...&FAM=RacoBoxes “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
From Raco Catalog
But Michael, how do we know it's actually listed for that use by UL?
If you read the instructions you will see that the box does not support the fan. The fan is supported by the framing member above that box.
• – Standard 514-C, File E104681 and R9320 • All versions of RACO® 7120 are UL approved for nonmetallic wiring systems • Boxes are listed for their Electrical Applications (Electrical Codes), UL Green Book • Boxes are listed for mechanical properties, including the 2-hour Fire Rating, (building codes) UL Orange Book • Federal Manufacturer’s number 28488 You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
If the fan is supported by the framing member then the box isn't required to be rated for fan support. The NEC gives you the option of using a fan box or supporting the fan independently of the box. The key wording in the requirement is sole support. I've used the box in the OP and happen to like them.
But the box has picture of a fan and home depot sells it so it must be ok
These boxes are very strong. I have used them before. This wouldn't be my first choice, but I would definitely use it if I found myself in the situation where my box placement was directly in the middle of a truss. It gives you some space to put your wire connections.
That box does not have to be strong since it is only a place to make the splices. It is not providing the support for the fan. The fan is hanging on two long screws into the framing member.
I have used this box for several years and find it to be universal and prefer it to most boxes rated for fan support. Using this box mounted to a framing member provides for a much sturdier and less flexing fan installation, but as with any thing else it is only as good as the installer wants it to be.
I just used one of those boxes a few weeks ago. As others have stated the fan is supported to the structure with the long screws supplied with the box. The box is for the electrical wire splices.
As I recall, all of the directions were clearly printed with the box. If you don't like this box, don't use it. There are plenty of other products that work. David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
The box does not support the fan that weighs about 35 lbs. The rating is for the hardware that comes with the fan. The hardware and screws supplied are to get the 70-75 lb. rating support. Plastic, steel, the goddarn blocking and screws are holding up the weight. ![]() ![]() Hope this makes it more understandable. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I was starting to get that deja vu feeling.
And this one has a few violations.
I was waiting for that.
That is the only picture of the bracket that supports the fan I could find. Thanks for bringing it up. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Plaster Ceiling Systems - Hidden Danger | Philip LaMachio | Interior Inspections | 3 | 12/1/09 8:38 AM |
| Yep, The plastic Nail | mcyr | Structural Inspections | 6 | 3/23/08 10:53 AM |
| Asbestos ceiling tiles | scoslett | Interior Inspections | 30 | 10/20/07 2:30 PM |
| Gas changes for plastic vents in Canada | rcooke | Canadian Inspectors | 0 | 7/30/07 2:15 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 4 | 1/22/07 12:24 PM |
