Old 7/6/09, 10:22 AM
Tim Larsen Tim Larsen is offline
Default plastic wire gauge tool
Howdy,
Where can I find a plastic wire gauge identifier.
I haven't had much luck searching for one.
TIA,
Tim
Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America)
Old 7/6/09, 11:03 AM
Default Re: plastic wire gauge tool
OK.... don't suggest anything be stuck in a panel and I dont trust the slip over gauges to be honest with you. If you want to do it the RIGHT way then to a search for a "digital plastic caliper" and then use the properties of Table 5 and Table 8 of the NEC to give you the most accurate readings. The calipers are plastic and non-conductive and digital ones are the best.
My prefered method is to learn the sizes and keep samples and create your own sample stringer to refer to....but if you MUST stick something in wear gloves, eye protection and use only plastic tools like the one described above.
Paul W. Abernathy
Old 7/6/09, 11:06 AM
If enough people ask me HOW to do this...I will create a video on it and how to be safe in doing it. I seem to get alot of questions regarding sizing and so on, Using a "Plastic" caliper is one method that will work and is rather accurate as long as you can determine the type of insulation being use..which is fairly easy for the most part.
Paul W. Abernathy
Old 7/6/09, 12:10 PM
gbeaumont's Avatar
That's what I teach too, far safer to buy a few feet of the common sizes and learn them than to go shoving things into panels IMHO. you never know when your going to find a loose wire or breaker.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Is there a tool for determining the gauge of a wire? amiller1 Electrical Inspections 14 3/22/07 12:39 PM
wire gauge / breaker rating jweinberg Electrical Inspections 19 7/16/06 4:36 PM
