Old 4/10/08, 2:43 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Please check me on this one....
A 90-amp twin breaker fed an HVAC unit of the roof of this condo. The two hots were connected to the breakers in this sub panel. The neutral was not connected to the neutral bus bar. An equipment grounding conductor from that cable was connected to the ground bus. Is the ground carrying the return of the circuit? Doesn't seem right.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 4/10/08, 2:53 PM
Michael Larson's Avatar
Default Re: Please check me on this one....
You'd have to look at the other end in the roof top unit to see in the white is terminated there or not.
The roof top unit doesn't necessarily need the neutral if it doesn't have 120 volt control circuits.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
You do not need a neutral on 220
Old 4/10/08, 2:59 PM
Bill Smith's Avatar
Thanks guys - I'm rushing between inspections and my brain is a bit twisted. I appreciate the help.
631-434-5200
Old 4/10/08, 4:34 PM
Unmoderated Guest
Like the others said, there is NO "return" in a 240v circuit. This is a line-to-line circuit, as opposed to a line-to-neutral circuit. In fact even 120v circuits have no "return", but that's another story.
A comment on teminology. The breaker in question is a two-pole breaker, or double pole, or 2-pole. It will NEVER be referred to as a "twin" breaker.
The breaker on the lower left IS a twin breaker, at least here in NY. It will get called many things across the country; twin, skinny, cheater, peanut, and more.
Old 4/10/08, 4:43 PM
relliott's Avatar
You forgot mini
Old 4/10/08, 4:52 PM
mnahrgang's Avatar
Question: Would there have been any harm or defect if the Neutral was attached to the buss bar?
Mark Nahrgang
www.HeyMark.info
Old 4/10/08, 5:05 PM
Jeffrey R. Pope's Avatar
None whatsoever. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/10/08, 6:58 PM
Unmoderated Guest
Originally Posted by relliott
You forgot mini
Damn! So I did.
Old 4/10/08, 7:32 PM
Marc D. Shunk's Avatar
Banned
and tandem.
Old 4/10/08, 7:51 PM
Gary T. Heller's Avatar
Isn't there a requirement for a neutral on any 220 v appliance with a 120 volt circuit?
Old 4/10/08, 8:02 PM
Banned
Functionally, it needs one, but there's no requirement. The equipment could just as easily have a transformer built into it for the 120V loads. Commercial laundry equipment and rooftop air conditioning units often do have a 240x120 control transformer. There is a general prohibition against using the neutral and jumpering it to also serve as the equipment ground, as was once done with ranges and dryers.
Old 4/10/08, 10:18 PM
Unmoderated Guest
Yes, but then it would not be a 240v appliance. It would be a 120/240v appliance.
Like Marc said, this generally applies to household cooking appliances and dryers.
Unmoderated Guest
Originally Posted by Marc D. Shunk
and tandem.
OK, leave me alone.
Procedural Inspection Checklist bgromicko Electrical Inspections 11 3/9/08 12:47 AM
inspection procedural checklist bgromicko Electrical Inspections 24 3/2/08 11:00 AM
Electrical Inspection Training for Home Inspectors jtedesco1 Inspection Education & Training 6 4/27/06 11:43 PM
