Old 2/27/08, 5:57 PM
William J. Decker's Avatar
Default POCO drop
Is there anything wrong with this.
Seems like the POCO can get away with a lot more than others can.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/27/08, 6:09 PM
Banned
Default Re: POCO drop
Is that temporary drop for a building being renovated/upgraded?
Old 2/27/08, 6:22 PM
Older apartment building condo conversion. The building was fully occupied and the buyer was buying a unit from the original buyer who bought 2 years before.
Here is another one. Doesn't this violate the "near a window" rule?
Will Decker, CMI
Old 2/27/08, 6:32 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
or shocking imagine only to survive the fire thinking that hey I'm going to jump and then you get the shock of your life. Where is the common sense
You only hope that when you hit the ground your heart restarts.
At least they could have provided a handrail??
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 2/27/08, 7:19 PM
Jeffrey R. Pope's Avatar
If there were a "near-a-window" rule, I would say yes , but there are "specific requirements" and it appears that this is a compliant installation.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/27/08, 7:20 PM
Bob Elliott's Avatar
From that pic the feeders are right on the cable line .
Old 2/27/08, 7:23 PM
I was taught that there cannot be a drop (or drip loops) within 3' (laterally) around a window.
Educate me, please.
Will Decker, CMI
Old 2/27/08, 7:33 PM
Sides and bottom only. The top of the "openable" portion of the window must simply be below the conductors.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/27/08, 7:39 PM
Thanks, Jeff.
Will Decker, CMI
Old 2/27/08, 7:41 PM
Here is the reference;
CEC 230.9(A) Clearance from Windows. Service conductors installed as open conductors or multiconductor cable without an overall outer jacket shall have a clearance of not less than 900 mm (3 ft) from windows that are designed to be opened, doors, porches, balconies, ladders, stairs, fire escapes, or similar locations.
Exception: Conductors run above the top level of a window shall be permitted to be less than the 900-mm (3-ft) requirement.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/27/08, 7:45 PM
Marc D. Shunk's Avatar
Banned
Curious why you opened this thread with one of your old pictures?
Old 2/27/08, 7:47 PM
David P. Valley's Avatar
William,
As Jeff stated, over the window is fine.
But it appears that your drip loop is hanging right next to the window opening. A clear Violation.....
"Click to Enlarge"
Old 2/27/08, 8:00 PM
Old 2/27/08, 8:07 PM
Sorry, Mark. I thought it was another picture (the one with the multiple drop cables spliced to the service drop) before.
Just call me the Department of Redundancy Department
Will Decker, CMI
Old 2/27/08, 8:09 PM
Originally Posted by dvalley
William,
"Click to Enlarge"
Attachment 18995
The drop is clearly (don't be fooled by the shadow) within the "openable" part of the window (the top also opens, and we do so, in Chicago. Old habits.).
Will Decker, CMI
Shop lights above a drop ceiling....? tdietrich1 Electrical Inspections 4 2/1/08 9:41 PM
Service Drop Dropped While at Inspection!! mlong Electrical Inspections 9 10/20/07 6:20 AM
Service Drop Q alarsen1 Electrical Inspections 11 2/25/07 9:45 AM
Service Drop Clearance Over Roof mlong Electrical Inspections 6 12/19/06 7:39 AM
Service Drop Was Finally Removed! jtedesco1 Electrical Inspections 1 12/1/06 2:40 AM
