Old 3/19/08, 9:46 PM
Jeffrey R. Pope's Avatar
Default Pool Equipment Bonding
I would like to hear opinions from everyone, expert or not.
Do you believe the metal pool filter should be bonded to the rest of the equipment? Why or why not?
I welcome any code interpretation you feel might be relevant.
In this case, the filter is about 8 feet from the water, so let's stay away from the five-foot rule and focus on the "equipment."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/19/08, 9:57 PM
Default Re: Pool Equipment Bonding
Hmmm, well it is metal, but it is not electrical equipment as stated in 680.26(4). I think it would be a stretch to call it part of the electrical equipment associated with the recirculating water.
Old 3/19/08, 9:59 PM
Besides, where would you drill a hole in the darn thing for a lug?
Old 3/19/08, 10:00 PM
Don't get caught up in the details . In this case it would be difficult, but many of these older filters have a steel base that you could tap a lug to.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/19/08, 10:09 PM
Marc D. Shunk's Avatar
Banned
It's not required to be bonded, and I can think of no benefit derived from bonding it at the distance from the pool you say it is.
Old 3/19/08, 10:17 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Well looking at the picture, there is separation from any metal piping that may connect the filter from the motor but there are signs of puddling in the area around the filter that head right over to the motor on the ground. I would mention, but not sure which direction I would head.
Stephen Stanczyk
Old 3/19/08, 10:27 PM
I don't believe it's required, but I've had AHJ's disagree with me, which is why I'm starting the discussion.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/19/08, 10:32 PM
Banned
Why would you care what the AHJ thought? Did you ask them if they have some local rule that modifies the base text?
Old 3/20/08, 12:19 AM
It's not about "caring" what they think. I'm trying to understand where their logic comes from.
I had been doing a "phase" inspection on a large custom home. After the pool and equipment was in (before the city inspector showed up), I inspected the installation - not for compliance, but for quality.
The owner questioned my "qualifications" when the AHJ said the filter needed bonding and I hadn't mentioned it.
The same type of issue came up again recently where the AHJ required bonding of the filter when some "other" work was being done on the property.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/20/08, 12:23 AM
Banned
They're just over stepping their bounds as an AHJ. Same old story. Happens to us electricians all the time on a variety of issues, and we resolve it by asking them for a code citation.
Old 3/20/08, 3:26 PM
Unmoderated Guest
Their logic comes from their opinions rather than facts. As Marc said, this all too common.
Old 3/20/08, 9:08 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am curious.
How is a metal pool filter not associated with the "pool water circulating system"?
In the picture, I see two pipes that I am assuming are carrying water circulating to the pool system.
680.26(B)(4)Electrical Equipment.
Metal parts of electrical equipment associated with the pool water circulating system,..."
I am not sure what the distance from the pool would have to do with this section...pool equipment is installed remote from pools all the time and still require bonding as per 680.26.
Old 3/20/08, 9:28 PM
Thanks Pierre. That's the kind of thinking I'm looking for. I can understand that. I just don't see it as "metal parts of electrical equipment."
You are correct - the pipes are carrying water as part of the "water circulating system." So what's your position?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/20/08, 9:37 PM
Brian E. Kelly's Avatar
National electrical standards require the metal filter in the equipment area to be attached to a common bonding wire that conveys errant electricity harmlessly to ground, which we recommend as a safety upgrade.
Boiler plate I use, bond it.
Old 3/20/08, 9:46 PM
The real question would be "how". Drilling a hole in the can would void the warranty and would need a gasket that would insulate the lug. You certainly couldn't connect a solid wire to a part that moves like the band or cover.
There is no code article that requires it
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
Dwelling and Commercial Electrical Equipment jtedesco1 Electrical Inspections 4 1/10/08 6:46 AM
