Old 6/8/06, 5:41 PM
mgoupil mgoupil is offline
Please Note: mgoupil is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default pool heater
hi just wondering if some one can show or explain how to wire the pool pump to heater correctly i live in canada any help would be very appreciated thank you!
Old 6/8/06, 5:55 PM
Roy D. Cooke, Sr's Avatar
Default Re: pool heater
Sorry if you have to ask then you should not be doing it .
My thoughts Roy sr
Old 6/8/06, 6:00 PM
Michael R. Boyett's Avatar
What does that mean? Wire the pool pump to the heater? Doesn't make much sense does it?
Old 6/8/06, 6:36 PM
Joseph Hagarty,  CMI's Avatar
Gas Fired Pool Heaters are wired and interlocked thru the Pool Pump circuit. If the Pump shuts down, so does the Heater.
I agree with Roy.
If you have to ask, maybe you should not be doing this due to Safety concerns.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/8/06, 7:30 PM
I was thinking, at least on the pool/heaters that I've had, that the heater had a built-in pressure switch that would not allow it to operate unless the water was circulating. Somewhat like a Klixon for a furnace. I just don't remember a separate interlock wiring for that function. I suppose there is though.
Old 6/8/06, 10:00 PM
Michael:
You are correct. A stand alone Heater uses the pressure switch.
The Control system on many of the pools (as well as my own) is what provides the interlocked control schemes.
The Jandy System is what I have.
http://www.jandy.com/html/products/c...s/onetouch.php
Joseph P. Hagarty
Phone: 610-399-3675
Old 6/12/06, 3:35 PM
The first answer was the right one, call a pro. There are several safety systems in a pool heater and you need them all wired in properly. You need to insure there is water pressure (the flow switch), that the heater stops before the pump (the fireman switch) and that this is all interlocked by the pump contactor so the heater could never run without power to the pump.
It's time for Professional Pool Inspections Revel L. Thom Ancillary Inspection Services & Additional Topics 13 7/26/07 10:50 AM
Pentair Water Pool Gas Heater Recall Gary Reecher Inspecting HVAC Systems 0 1/4/07 8:15 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
