James L. Evers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello-
We have a manufactured home in Montgomery, Texas that is always generating high bills. Any season, the bills are about $400. per month for a 3 br unit. We have elect ac and heat, a well, and the usual household appliances. We checked the well and it is running correctly. My question is, is it possible that we have a bad meter ? Any other ideas you have from the Member's vast experience here is greatly appreciated. Regards- James |
I would get a infra red inspection to see where the cold area's are
How effecient is your electric air / heat? SEER rating, etc.?
how old is the home also
any way possible posting some pictures |
Have an experienced electrician and a good HVAC tech come and check out the loads and equipment operation. Check for unknown current leakage to ground. If they find nothing, then analyze the building envelope for air leakage/missing insulation |
What is the cost per kwh there?
Around here its about 7 cents and your power bill sounds way out of line. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Electric heat or heat pump? Electric heat is like running a giant toaster day and night.
My worst power bills are in the winter and include running 6.5 tons of heat pump (3600sf at 71/72 deg), outside two person hot tub @104 deg, occasional electric strip heat for 1000sf detached shop, all electric house, water heater with instant hot recirc loop on timer.
At approx 7 cents per kwh I pay an average of $190 in the winter months and $100 average the rest of the year with 2 of us living there. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
You gotta trade that hot tub for a 1 man, 3 woman model.
Meter clock reading should be right on the bill. |
I had one of those at my first house and was single then, wish I had some pictures, maybe the neighbors have some.....
Even with our mild winters in Texas, electric bills with electric resistance type furnaces tend to be can be higher than our AC bills in the summer. Have you lived here through past winters and this bill is out of line from what you used to have?
I used to have a 20 yo condo with electric heat. My winter bills were always higher, even though I like it cool and didn't run it much in the winter / did run the AC in the summer. An Infrared efficiency scan would be helpful in identifying problem areas. Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
Thanks to everyone for their input. The utility provider is coming out today to check the nuetral and all the connections from the pole to the meter, and we'll start from there.
I was told that aluminum service wires are more likely to come loose than copper. |
Hi James,
I'm local to you. Give me a call if you need help. Chuck Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Thanks to everyone for their input on our problem. I hired an electrician that specializes in troubleshooting and he was great. It was Adams Electircal at 281-357-8078 , very reasonable rates and here's what we found.
1. Loose nuetral at the panel. 2. Loose nuetral connection in the crawlspace. 3. Other loose connections in the panel. 4. Checked all voltages at sources and they were good. The lights all are nice and even now and no more flickering. Utility company checked out there connections first from the pole to the meter. Thanks again. |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
| Electrical Safety Media Center | jtedesco1 | Electrical Inspections | 1 | 3/15/08 9:18 AM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
